Originally Posted by Prof. Dr. Silver Dude....have you seen these heatsink bottoms? You might need two tubes to fill those gaps...I think it is a great idea! I wonder what he's gonna use though...  |
The OCZ coolers have failed to impress to say the least.
I ebayed a thermaltake cooler a few years ago and when I got it, the bottom had a huge gash. I soldered the gash and did a light lap job to level it out.
Your best bet is solder the bottom enough to fill the gaps, polish it flat, and use a regular amount of thermal compound.
Solder conducts extremely well.
