Old February 25, 2011, 05:07 PM
CTA's Avatar
CTA CTA is offline
Default multi-fans adapter
i am trying to find good adapter to handle more tha 6 fans... but i only can find similar to
Akasa Thermal Solution
its not stocking at ncix...
so any suggestion?
i have two radiators that contains six zm-f3... my mobo has total 6 pins... but i need two for dual mcp355 with ek res v2...
no i dont want to do custom one...
edit: NCIX FORUMS - One Molex? - Fractal Design PCI-MOUNTED Fan Power Spl... is nice but i prefer cable...
Old February 25, 2011, 05:35 PM
one you listed, first one, couple of those plugs has resistor built in so those ones will run at slower speed
Old February 25, 2011, 05:51 PM
ZZLEE's Avatar
Molex to 3 pin fan STARTECH 3 LEAD TO HARD DRIVE POWER CPU FAN ADAPTER cpufanadapt
Fan splitter 12" long 12IN TX3 FAN POWER SPLITTER TX3SPLIT12 they have some 6" ones fore 1 $
Or Fan contoller Black Sunbeam Rheobus Extreme Fan Controller 30W x 6 channels Sunbeam Rheobus Extreme Fan Controller [] - $35.99 : DazMode, Canadian PC Water Cooling and Modding Store
try this
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old February 26, 2011, 03:01 AM
CTA's Avatar
CTA CTA is offline
sorry i forget about this... was busy working on leak stuff ;p
anyway...
no, it said "Choice of fan operating speed (5V and 12V connectors)" so i guess not...
the product that you suggest seems not good... they use too many space... and spliter (2 into 1) is too small... i want 4 in 1 or more ;p
and never fan of fan controller... screw them... ;]
Old February 26, 2011, 04:25 AM
anyway...
that just means couple of those are actually marked with what voltage it is. I have a couple that came with a noctua heatsink and it's marked 12v and 5v and some other ones i bought aftermarket so the "choice" isn't exactly for every connector on there. say if it had 2 connectors 1 will be 5v and another one will be 12v.
edit: this is copied from the spec : 4x 3pin (2x standard speed, 2x reduced speed +5V)
Old February 26, 2011, 12:33 PM
CTA's Avatar
CTA CTA is offline
you are right... just look at color (yellow and red)... but its easy to do a simple mod..
anyway... i have no choice to get this NCIX.com - Buy 6 IN. TX3 Fan Power Splitter Cable - Startech.com Ltd - TX3SPLITTER - in Canada :?
Old February 26, 2011, 12:40 PM
you can and that will fit your bill but it's only 2 splitter though but you can get more than one
Old February 26, 2011, 02:29 PM
CTA's Avatar
CTA CTA is offline
yes i will take 4...
Old February 26, 2011, 02:35 PM
ZZLEE's Avatar
I see some sleeving and heat shrink in your feuter.
I just saw some heat shrink in the automotive section of Home Hardware today.
Old February 26, 2011, 03:16 PM
CTA's Avatar
CTA CTA is offline
feuter? what does that word mean?
i have heat shrink in my car glover (at my brother's place) but i need heat gun... and i am not good at doing electrican... need tools and training from pro... >_>;
plus my goal is not do mod other than case >_>;
[WTB] Fans. Lots of fans. gray mole Buy/Sell & Trade 1 December 29, 2010 02:20 PM
[FS] New Zalman fans, used Scythe and blue LED fans mhw100 Buy/Sell & Trade 15 June 22, 2009 02:32 PM
Multi Monitors Infiniti Display Units 1 December 7, 2008 10:55 AM
Multi-PI for multi-cores? francois methot Overclocking, Tweaking and Benchmarking 17 May 5, 2007 02:18 PM
