Old February 26, 2011, 03:57 PM
ZZLEE's Avatar
GELID Sleeved Fan Power Y-cable splitter GELID Fan Power Y-cable splitter [GELIG PWM Y-cable] - $3.78 : DazMode, Canadian PC Water Cooling and Modding Store
Daz has some black ones
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old February 26, 2011, 04:00 PM
CTA's Avatar
CTA CTA is offline
"connect a series of up to 5 PWM fans"
is it a joke? i need the actual picture...
but if its just normal 2 in 1 then imho, its not worth... 1cdn is better and it will hide the back of the mobo...
geez... two for 8+14 (22) to get here... so i rather to get from ncix...
Old February 26, 2011, 04:31 PM
yeah.. description is quite deceiving...
GELID Solutions > Products
so in reality like the picture from daz and gelid site itself. it only connects 2 fans but it's PWM instead of normal 3 pin
Old February 26, 2011, 04:35 PM
JD JD is offline
These are what you want:
Phobya Y-Cable 3Pin Molex to 4x 3Pin Molex 60cm - Black Products Model: PH-81038 [PH-81038] : Performance-PCs.com, ... sleeve it and they will come
Phobya Y-Cable 3Pin Molex to 6x 3Pin Molex 60cm - UV blue Products Model: PH-81045 [PH-81045] : Performance-PCs.com, ... sleeve it and they will come
Phobya Y-Cable 3Pin Molex to 9x 3Pin Molex 60cm - Black Products Model: PH-81049 [PH-81049] : Performance-PCs.com, ... sleeve it and they will come
I had some of those cheap splitters and they didn't seem to work for whatever reason. However I have the 4-fan one from Phobya now which works perfectly.
Old February 26, 2011, 05:02 PM
CTA's Avatar
CTA CTA is offline
estimator calculator is not working...
Phobya Y-Cable 3Pin Molex to 4x 3Pin Molex 60cm - Black Products Model: PH-81038 [PH-81038] : Performance-PCs.com, ... sleeve it and they will come two for 10usd plus what?
Old February 26, 2011, 05:58 PM
Dr_BenD_over's Avatar
Fallen Folder
Get a soldering iron and make one?
All's well that's Haswell
Old February 26, 2011, 08:28 PM
JD JD is offline
Originally Posted by CTA View Post
+$4 to Toronto.
Old February 26, 2011, 08:30 PM
CTA's Avatar
CTA CTA is offline
thats very cheap...
okay i will sign up and find out then possibly ship to here...
mr bend, i already told about it...
edit: strange 13.99 USD=13.6738 CAD but i just had to pay 14.06 CAD... o_O?
[WTB] Fans. Lots of fans. gray mole Buy/Sell & Trade 1 December 29, 2010 02:20 PM
[FS] New Zalman fans, used Scythe and blue LED fans mhw100 Buy/Sell & Trade 15 June 22, 2009 02:32 PM
Multi Monitors Infiniti Display Units 1 December 7, 2008 10:55 AM
Multi-PI for multi-cores? francois methot Overclocking, Tweaking and Benchmarking 17 May 5, 2007 02:18 PM
