  #31 (permalink)
Old February 25, 2011, 01:34 PM
That looks horrible. Sidenote; looks like TA rads are on the way out, and XSPC are on the way in @ ncix.
  #32 (permalink)
Old March 1, 2011, 08:25 AM
Rison's Avatar
Originally Posted by Mekaw View Post
seems like the gunk crap isn't new, I've searched around on overclock.net and saw couple of threads and posts about it.. I heard thermochill is quality rad but their quality control is in the drain
Um, yeah.. they've always had that problem. But you said it was a new line and ROHS compliant, so I didn't complain too much before you bought it.
I'd personally send it back, even still. But I flush with vinegar and water.. than put a bunch of isopropal alcohol and shake the living crap out of it.. then flush with more water.. then vinegar/water.. etc, etc.
I'd try to put another fan on your rad to, near the top.. so 2/3 will be push/pull at least.
I'll learn to manage my anger, when people learn to manage their stupid.
  #33 (permalink)
Old March 1, 2011, 09:21 AM
AmuseMe's Avatar
All radiators will have flux gunk in them all of them. ThermoChill just seems to have more of it I've mentioned this before, and have had one myself. If you want a clean radiator - get it chemical bathed, and ultrasonic cleaned
  #34 (permalink)
Old March 1, 2011, 02:19 PM
yeah, everywhere i searched said it's ROHS compliant.
anyways I've already put fans in push pull
Speaker Recommendation jcmaz Audio 4 July 13, 2009 06:39 AM
PSU recommendation? SugarJ Power Supplies 6 March 26, 2009 09:26 PM
Need a Case Recommendation shryke Cases 12 October 7, 2008 09:11 PM
LCD recommendation ElAguila Display Units 1 August 24, 2008 06:18 PM
Speaker Recommendation sswilson Audio 8 February 22, 2008 09:23 PM
