Old February 13, 2011, 12:31 AM
CTA's Avatar
CTA CTA is offline
Default hd 6950 cfx connector
i did search and found some information... i had two hd 6950 cfx so i need connector like
Dual VID Connector, Adjustable 1 Slot Spacing - Water cooling systems, pc liquid cooling kit, cpu, video card, hard drive
or Dual VID Connector, Adjustable 2-3 Slot Spacing - Water cooling systems, pc liquid cooling kit, cpu, video card, hard drive
those parts is available ncix (one business day)...
i know i did check that i need one slot connector (i would like 3 slot but i cant because i have customize case and flat bar will block the holder thingy)... and i believe short distance one is the best...
so i tried to find other than koolance... yeah i am cheap person... i only found one tpc at SLI VID Connector - G 1/4 - 1/2/3 Slot - Silver SLI VID Connector - G 1/4 - 1/2/3 Slot - Silver [1403] - $8.99 : DazMode, Canadian PC Water Cooling and Modding Store but i had to pay shipping for 15 wait for 4 days ;[
do you know other source? or different brand at ncix? such as bitspower d plug? (disconnected?)
i also wonder about "two blocks in parallel" connector... see below the page..
would it be benefit compare to the "two blocks series"?
OC gtx 560 sli vs OC hd 6950 (with hd 6970 flash) cfx CTA Video Cards 8 January 27, 2011 04:54 PM
Which connector do I need? Fudd Rucker Water Cooling 13 January 25, 2011 09:18 AM
5870 Vapor-X, Dirt 2, Q6600, CFX vs Non-CFX zc1 Video Cards 2 March 20, 2010 08:41 PM
Anyone seen a 3>1 fan connector around? Jmark Water Cooling 5 October 19, 2009 03:33 PM
Need help with 3870X2 CFX blank screen issue! Killswitch Troubleshooting 13 September 15, 2008 07:06 PM
