Old February 14, 2011, 09:36 AM
Rison's Avatar
Your resevoir is still upside down, and doing the 'waterfall' effect of putting excess air in the water.
Even though it's a long res, I wouldn't want to keep it that way. You may want to secure the res a little better too.
Cabling is getting better though.
I'll learn to manage my anger, when people learn to manage their stupid.
Old February 14, 2011, 10:16 AM
Shadowmeph's Avatar
How do you know it is upside down? what I mean is does it matter which way that type of resevoir sits?
Old February 14, 2011, 10:53 AM
okay well if u look at the rez stock.
all i did was take that inner tube placed it on the bottom flipped the rez so i can use the "L" for a smoother connection to my rad. so i don't get that "waterfall" issue
Old February 14, 2011, 11:30 AM
Could shorten the run of the tubing from the outlet of the radiator to the inlet of the reservoir.
Old February 14, 2011, 12:29 PM
Talking
hows this ?
Old April 19, 2012, 09:51 AM
Adzsask's Avatar
Looks about 20 times better then my case hahaha, I could care less about the inside of my old beater case, no place for cable management at all in my case, I used to only put every second screw in everything like you did, until a fan shook loose one day and cut the heck out of my hand, found my PC was a whole lot quieter after i threw all the screws in, one gripe I have is the fan wires up top, spin the fans so the wire is at the back, other then that you cleaned it up about as good as it could get. One more tiny gripe, matching fans look, and work a whole bunch better then 1 black 1400RPM, one clear 1000RPM fan.
Old May 10, 2012, 05:55 PM
i agree about the fan wires! also, i personally wouldnt have that ram cooler on there, but to each their own, i suppose
