  #31 (permalink)
Old February 13, 2011, 10:35 PM
Dazmode's Avatar
Clean build. Congratulation on putting it together. It seems you have enough clearance to get two more fans under your rad in case you would need bit more punch.
Orange Build: Final Video
HTPC Build: Final Video
  #32 (permalink)
Very clean loop , how are the temps.
  #33 (permalink)
Old February 13, 2011, 11:42 PM
naw, there's ram and pwm heatsink getting in the day.
temps arent that great, as most people suggested here, I should go pick up another 240 rad or shouldve gone with thick 360mm rad and place it outside.
  #34 (permalink)
Old February 14, 2011, 04:38 AM
Rison's Avatar
Nice clean loop, it looks nice.
I agree with Daz though, i'd shoehorn in two more fans.. it looks to me like it would fit. Always exaust out of the case, you figured out why. :)
There are also slim 15mm and 20mm fans that could do the trick.. they don't have a lot of static pressure though. I always liked it best to have the same fans on either side of the rad.
Removing the shroud on the top of the case is definitely the way to go - but I understand if you don't want to cut up the case.. I always keep in mind for reselling in the future when i'm doing case mods / etc.. always being able to revert back.
For purely astetics, the tubing from the pump to GPU is a bit too long. An inch or so off would have the tubing horizontal to the rig.
Do you have zip ties on the GPU / CPU tubing by the barbs? I kind of looks like you do.. but it's well hidden with the photos at least.
edit: oh, I see the ram channels in the way now.. that sucks.
I'll learn to manage my anger, when people learn to manage their stupid.
  #35 (permalink)
Old February 14, 2011, 06:33 AM
yeah I'm using those swiftech clicky lock thing.
no i cant really fit any fans inside the case, there's ram in the way and towards back of it there's pwm heatsink that gets in the way also.
yeah I didn't have any 45deg fittings or else i would've used it on pump to gpu, gpu to cpu and cpu to rad for much shorter hose and probably looks a lot cleaner but they are expensive =/
mm if i made that gpu= pump hose any shorther there's going to be a bend or kink, tube starts to collapse a bit.
  #36 (permalink)
Old February 20, 2011, 03:29 AM
here's an update, hoses don't look so "neat" anymore but it's all good. new mobo was installed and another 240 rad
  #37 (permalink)
Old February 21, 2011, 12:19 PM
Dazmode's Avatar
Still neat for my eyes, although few 45 degree adapters will make it even better. The only thing I would add is two PCI-e white braid cables om GPUs
  #38 (permalink)
Old February 21, 2011, 01:32 PM
yes, I've been contemplating whether to get white or black at your store along with 4 45 deg pack.
just waiting to see what else I can pickup to get the most out of shipping
  #39 (permalink)
Old March 11, 2011, 10:01 PM
DRYJESUS's Avatar
Restricted Poster
how's the ek bay spin? is it very loud?
  #40 (permalink)
Old March 12, 2011, 03:04 AM
I'm not using it anymore but it is for sale.. I'm using frozen q liquid fusion now.
Pump orientation question ADay2Long Water Cooling 10 December 13, 2010 12:31 PM
Pump orientation Fudd Rucker Water Cooling 10 August 6, 2010 12:37 PM
Another loop order, single/dual loop thread... turtletrax Water Cooling 8 July 28, 2010 08:40 PM
loop and or pump question gomer Water Cooling 5 June 8, 2010 06:48 PM
enough pump for full loop. kyle_L Water Cooling 5 February 27, 2009 10:04 AM
