Old February 11, 2011, 11:09 AM
Yeah always res before pump and any order that follows next.
If you are internally adding a 120mm to the rear the top 240 may obstruct it..
Old February 11, 2011, 11:20 AM
is it okay to mount mcp35x vertically?
Old February 11, 2011, 04:07 PM
Rison's Avatar
you can mount a pump any direction you want.
I'll learn to manage my anger, when people learn to manage their stupid.
Old February 11, 2011, 04:58 PM
As long as water will flow from the reservoir to the inlet, you are good to go.
Old February 11, 2011, 07:43 PM
moar toys arrived, props to daz at dazmode for great packing job and fast shipping!
Old February 11, 2011, 08:08 PM
Nice.. enjoy putting your loop together, it's a good experience
Old February 11, 2011, 08:26 PM
I'm having second thoughts about rad though. I might pickup another 240 rad and place it in front so it'll be one up top and 1 up front.
Old February 11, 2011, 09:18 PM
:-) don't worry thats the watercooling effect ehhe.
I must have changed my loops 4 or more times before i was satisfied..
I've switched rads, different reservoirs.. fittings, tubing colour, all sorts of things until I was satisified..
I went way over my intended budget.. but it became another aspect of pc building that I enjoy.
  #19 (permalink)
Old February 11, 2011, 09:27 PM
matari's Avatar
Lightbulb
The only requirement is res outlet to pump inlet. But it is easier to bleed up through the gpu. The rest of the loop order does not matter with proper flow and enough rad.I wonder if you could move the HD to the drive bays and put 120mm single were the HD use to be. That should be enough cooling for both. cpu and v
gpu.
  #20 (permalink)
Old February 12, 2011, 07:12 AM
Rison's Avatar
I've run a GTX480sc oc'd and 980x oc'd to 4.3Ghz on a triple TFC rad. People screamed bloody murder that it would be terrible.
I only had 3x fans on on side pushing air through the rad (Scythe SFLEX) - and the loop ran at 52c. well, thats what temp monitors showed for the GPU/CPU.
If you have room to sandwich fans on the rad, I think you'd be doing well. I would try that out before spending more money on another Rad.. you will be tearing your loop apart over and over again anyways.
Pump orientation question ADay2Long Water Cooling 10 December 13, 2010 12:31 PM
Pump orientation Fudd Rucker Water Cooling 10 August 6, 2010 12:37 PM
Another loop order, single/dual loop thread... turtletrax Water Cooling 8 July 28, 2010 08:40 PM
loop and or pump question gomer Water Cooling 5 June 8, 2010 06:48 PM
enough pump for full loop. kyle_L Water Cooling 5 February 27, 2009 10:04 AM
