Old February 10, 2011, 08:52 AM
Default Sounds of water bubbles
I swear I have been hearing the odd air bubble in my loop the last couple days. When I move my ear closer to my PC it stops. So I cant be 100% sure but Im 90% sure Im hearing air bubbles. I didnt have this issue with my old case. How long can bubbles really take to filter out? I have had my loop going for about 6 weeks now.
Old February 10, 2011, 09:38 AM
Dazmode's Avatar
Should be clean by now. Although it seems always some air get trapped in the loop. When i restart my my system I can hear something when pumps start spinning, but after that it is silent.
Orange Build: Final Video
HTPC Build: Final Video
Old February 10, 2011, 09:54 AM
martin_metal_88's Avatar
I've been doomed to run my loop for like 6-8 month with a bubble trapped in the pump. Never win against her. But most of the time she will go out one day.
Old February 10, 2011, 10:43 AM
How full is your reservoir? I found that when I filled by reservoir up to 90% the dripping noises went away.
Old February 10, 2011, 11:54 AM
It is about 60% full. I have noticed the level drop a bit. Which was part of my conclusion about the bubbles. I'll try filling up the rez and see if that helps. It isnt a huge issue. Ive only noticed it a couple times.
Old February 10, 2011, 12:54 PM
yeah give it a shot. i find that in my reservior if it isn't full the water turbulance is too much and it starts wooshing around everywhere making dripping noises.
Old February 10, 2011, 02:35 PM
not supposed to drop too much too fast, usually if im not lazy i keep me rez's filled up almost to the brink, a bit extreme but works :p
Old March 11, 2011, 12:48 PM
It had been a couple weeks for my levels to drop. But, as an update. I filled my res up and sounds are gone. Very relieved. Ty for the tip!
Old March 12, 2011, 09:13 AM
mataribot's Avatar
It is not possible to get all air out of your loop. If turn your computer off that air in your reservoir will always work it way into the loop. Once most of the air is out, I just leave my computer on 24/7 and I do not have much of an issue with it.
Buzzing sounds in headphones Kilauea Troubleshooting 6 October 12, 2010 09:08 PM
Sounds fine No display leland459 CPU's and Motherboards 3 September 14, 2010 12:51 PM
Sounds like a dying mobo Arinoth Troubleshooting 3 July 20, 2009 05:54 PM
Zounds, no sounds Dr_BenD_over Troubleshooting 2 December 10, 2008 04:10 PM
Beeping sounds - Something Amiss??? Bognostraglum Troubleshooting 2 May 4, 2007 07:19 AM
