Old February 9, 2011, 07:31 PM
Prolab's Avatar
Default O-ring installation on EK block
You guys have any tips??
This thing is pissing me off
Ive already snip 2 o-rings cause it wont stay in the grove while im tightening the bolts down. Ive got recommend to use this sparringly to hold the o-ring down:
DOW CORNING Silicone High Vacuum Grease 976V Stopcock - eBay (item 280543635276 end time Feb-28-11 22:29:48 PST)
I have 4 more o-rings, but i want to use them as spares. TBH, ive spent more time installing the o-ring compared to planning, sleeving and installing my WC gear in my rig.
Currently im soaking the o-ring overnight on distilled water. Not sure if its gonna help...
Gaming Rig:
-Caselab STH10, Swiffy MCP35x2, (2) Aphacool UT60 480 rad, HWL GTX 360, Heatkiller IV, i7 5930k @ 4.5 Ghz, 16GB Ripjaws, Asus X99 Deluxe ii, (2) XFX R9 290 w/ XPSC WB, 240 GB Intel 530, 500 GB 850 EVO, (6) 3 TB Tosh HD, EVGA G2 1300 PSU, Win 10 Pro
HTPC Rig:
-G3258 @ 4.0 Ghz, Asrock Z97 Pro 4, Asus 290, 128 GB Crucial M4, (2) 2 TB WD Green, (1) 2 TB Sammy F4, (2) 5 TB Tosh HD, Enthoo Primo, XSPC 480, 240 HWL GTS, Corsair HX620, Win 10 Pro
Old February 9, 2011, 07:34 PM
What EK Block? Supreme HF? I don't recall anything to have to do with O-rings.
Old February 9, 2011, 07:38 PM
Prolab's Avatar
Sorry, its the supreme HF. I had to take the intel bracket off and install the AMD on. Hence the 2 accidental snips of the o-ring.
What a pain
Gaming Rig:
HTPC Rig:
Old February 9, 2011, 07:49 PM
Oh so you had to take apart block to switch it to amd.. hmm well soaking it overnight in distalled water wouldnt do anything... how about boil it in some distalled water.. this will loosen up its form.
Old February 9, 2011, 08:00 PM
I think you are trying to install the block in the wrong order. The o-ring on mine is incredibly easy to install. Unless you have replaced the stock one already? How do you know the replacement is exactly the same size?
Old February 9, 2011, 10:07 PM
Prolab's Avatar
Well, ive installed it wrong the first time. So i bought 5 replacements from EK (came from Slovenia out of all places!) and i got it this afternoon.
Im gonna try to boil some distilled water when i get home.
If that doesnt work, is there a adhesive that i could use to just hold the o-ring in place
Gaming Rig:
HTPC Rig:
Old February 9, 2011, 10:19 PM
hmm maybe its not a good idea to boil the ring because it will become really flimsy and the idea is to keep it firm so that you can put it on it's groove.. I really have no experience with the matter =/.
Old February 9, 2011, 10:20 PM
Spikemaul's Avatar
I work with hydraulics everyday and I use good ole Vaseline to hold those tricky o-rings in place.
Old February 10, 2011, 12:03 AM
matari's Avatar
I am sure that EK uses some sort of lubricant to hold the O-ring in place. That would be that nasty crap I had to clean off when I first got my block. I have never used the AMD insert, but with the intel black mount holds the O-ring in place. I just hold it there for a few mins, place my the face of block back on hold tight and screw in. Never had any issues. You can probably use a lubricant like vaseline, but make sure not to get any on the microfin area. One last thing, make sure you test your block for leaks outside of your case first. One time I forgot to put the O-ring in. Lol.
Old February 10, 2011, 02:10 AM
Prolab's Avatar
The AMD inserts are pain. Ive gotta say, EK needs to rework their mounting brackets for AMD/Intel. Maybe re-design it so you dont need to take the block apart, just have the mounting brackets put on either on the top or bottom.
Nonetheless its a pain! Well, i have been leak testing outside my rig after my firsty incident. Im going to see if using vaseline would help keep the o-ring in place.
Gaming Rig:
HTPC Rig:
[WTB] WC parts (pump, res, tubing, chipset block and 4850 compatible GPU block) donimo Buy/Sell & Trade 5 February 2, 2009 12:53 PM
Red Ring of Death bites MS in the butt...LIVE SKYMTL Press Releases & Tech News 27 February 22, 2008 01:53 PM
Help with 2900xt installation SirenOfDarkness Video Cards 15 September 9, 2007 01:40 AM
Installation of Windows XP enaberif O/S's, Drivers & General Software 3 January 24, 2007 11:54 PM
