Old February 10, 2011, 10:35 AM
I never found any trouble with switching the brackets. When I popped it off to insert my AMD bracket, the O-ring stayed where it was on the top cover. Guess it was fortunate for me
Hopefully that Vaseline trick works for you.
Old February 10, 2011, 06:29 PM
Dazmode's Avatar
Oh, yes! Those o-ring are hard to put in.
I used a trick of putting them in groove, fix it with transparent glass (make sure it is in), cool in freezer (so it harden), then assemble...
Orange Build: Final Video
HTPC Build: Final Video
Old February 10, 2011, 07:04 PM
Prolab's Avatar
Originally Posted by matari View Post
I am sure that EK uses some sort of lubricant to hold the O-ring in place. That would be that nasty crap I had to clean off when I first got my block. I have never used the AMD insert, but with the intel black mount holds the O-ring in place. I just hold it there for a few mins, place my the face of block back on hold tight and screw in. Never had any issues. You can probably use a lubricant like vaseline, but make sure not to get any on the microfin area. One last thing, make sure you test your block for leaks outside of your case first. One time I forgot to put the O-ring in. Lol.
Damn, that would be pretty handy. Hopefully i dont need to that next time around .
Well, ive finally used a good amount of vaseline along the groove of the bracket/top part of the block. It stayed put!!
Now im just leak testing, but there's some trickling along the compression fitting and the corner part of the block. I just tighten it a bit more and 23 more hours to go!
Thanks for the help guys!
Gaming Rig:
-Caselab STH10, Swiffy MCP35x2, (2) Aphacool UT60 480 rad, HWL GTX 360, Heatkiller IV, i7 5930k @ 4.5 Ghz, 16GB Ripjaws, Asus X99 Deluxe ii, (2) XFX R9 290 w/ XPSC WB, 240 GB Intel 530, 500 GB 850 EVO, (6) 3 TB Tosh HD, EVGA G2 1300 PSU, Win 10 Pro
HTPC Rig:
-G3258 @ 4.0 Ghz, Asrock Z97 Pro 4, Asus 290, 128 GB Crucial M4, (2) 2 TB WD Green, (1) 2 TB Sammy F4, (2) 5 TB Tosh HD, Enthoo Primo, XSPC 480, 240 HWL GTS, Corsair HX620, Win 10 Pro
[WTB] WC parts (pump, res, tubing, chipset block and 4850 compatible GPU block) donimo Buy/Sell & Trade 5 February 2, 2009 12:53 PM
Red Ring of Death bites MS in the butt...LIVE SKYMTL Press Releases & Tech News 27 February 22, 2008 01:53 PM
Help with 2900xt installation SirenOfDarkness Video Cards 15 September 9, 2007 01:40 AM
Installation of Windows XP enaberif O/S's, Drivers & General Software 3 January 24, 2007 11:54 PM
