Old February 9, 2011, 08:08 PM
hmm.. Enough where if I keep screwing the compression fitting in, it will start grinding away the pcb.
I'd like to keep the backplate on and not to modify the backplate.
Old February 10, 2011, 05:53 AM
Rison's Avatar
Although i'm not a fan of parallel'ing your video cards, it does look very nice.
I would probably still try the small, clear or white (painted) zip ties.. and work with the backplate to orient the ziptie head out of the way. You can get some increadibly skinny/flat 2" zip ties that would be enough to hold the tube at an electronics store or something.
I'll learn to manage my anger, when people learn to manage their stupid.
Old February 10, 2011, 09:22 AM
Keywork's Avatar
I would probably leave it as is and throw on some fancy koolance clamps (I personally use them in my loop).
Old February 10, 2011, 09:33 AM
Dazmode's Avatar
BP rotaries should work. Another option would be use standard SLI kits but sleeve them with white tube for looks.
Orange Build: Final Video
HTPC Build: Final Video
Old February 10, 2011, 10:59 AM
I wish I could do that but there is no room for clamps, the pcb is in the way.. I have about a paper thin gap between tubing and backplate.
Old February 10, 2011, 11:02 AM
Yeah rotaries are going to work, just won't look as pretty.. Never thought about sleaving an SLI kit.. hmm..
Well.. I'll install the rotaries and see how they look tonight.. I think I'll be more comfortable with compression fittings than barbs with no clamps or zipties.
Old February 10, 2011, 08:00 PM
Installed and pictures up for anyone curious!
Old February 10, 2011, 08:12 PM
ZZLEE's Avatar
Looks nice to me
Now some blacklight to make them glow
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
  #19 (permalink)
Old February 10, 2011, 08:16 PM
hehe thanks,
No use yet until I get a window side panel for my 700D lol.
  #20 (permalink)
Old February 10, 2011, 09:32 PM
Dazmode's Avatar
Wow, looks nice! Would never guessed it will look that good. Interesting.
Guide : Sleeving a 3-pin fan! (56k Warning) Patriote Guides & How-to's 56 March 18, 2011 01:59 AM
Gallery H55N-USB3 (lots of pics, 56K warning) zoob Case Mods, Worklog & Gallery 6 August 31, 2010 03:52 PM
Need some barb/fitting advice (W/C noob) Aix Water Cooling 8 July 29, 2010 10:23 PM
Show off your F@H farms! (56k warning) Silvgearx HardwareCanucks F@H Team 246 April 23, 2010 07:06 AM
Dry Ice [Warning 56k] CanadaRox Case Mods, Worklog & Gallery 27 March 14, 2008 08:51 PM
