-   -   cleaning a reservoir (http://www.hardwarecanucks.com/forum/water-cooling/40526-cleaning-reservoir.html)
HiTi February 5, 2011 07:10 AM
I was going thru another box of gear I had forgotten about and came across this
It is still in great shape, but there is some residue left from the last time I used it (A64 days) What could I possibly use to clean it that wouldn't be harmful to the joints? Dish soap? I'm thinking I might use it again if it doesn't leak
Thanks in advance
gingerbee February 5, 2011 09:02 AM
dish soap should be fine i have never had a problem with it, but it might not get out all the yucky stuff. you can use some orange cleaner i always finds that works for me. my2cents
HiTi February 5, 2011 09:15 AM
I never even thought of that....that would proby work perfect
Thanks!
JayDeeHobbit February 5, 2011 09:22 AM
I had stains on my rez and it was difficult to get off completely.
I used vinegar in it and shook it for awhile and it fot most out. Then I stuck a Q-Tip in it to apply physical cleaning to the areas I could reach. Then with the vinegar again.
That process got most of the stains off for me.
When done I just put some distilled water in it and shake it up again and it will get rid of the vinegar that remains.
sswilson February 5, 2011 11:08 AM
The dollar store will probably have some small "Baby Bottle Nipple" brushes which are perfect for this kind of cleaning/scubbing. (Much better than a Q-Tip)
JayDeeHobbit February 5, 2011 11:29 AM
Cool sswilson :)
I also love the dollar store = just walk around in there and you never know what handy liitle gadget will pop up.
Must make a mental note for baby bottle nipple brush next trip.
gingerbee February 5, 2011 04:01 PM
no kidding eh i am so addicted to the dollar store. off-topic i know sorry
