Originally Posted by Ebbtides On another note, two loops seem excessive for a 1100t, ram, and two 6970's?
Still deciding on the rads I should cram into my 800d. |
If you are doing triple and a dual internally in the 800D it should be fine with a single loop depends how far you want to overclock. If your going for dual loops put 240 on the cpu and 360 on the graphics.
Dual loop should save you a few degrees as you don't have to share the heat from other waterblocks.. but usually cost more in the end.
To give you an idea of temps, I have a quad and a dual internally in a 700d under a single loop. I am cooling a 920 @ 4.4 ghz and two Gtx 580's at 950/2200.
With ambient tempatures of 28 degrees .. My processor hits high 70's and my GTX 580's hovers around the low 60's should be better when I put them in parrallel. Theres a max 10 degree difference between the top and bottom cards at the moment.
