<~----> Thermocouple Probe Question - Page 2 - Hardware Canucks
Old February 4, 2011, 12:26 PM
Reyzac's Avatar
Where do I access the temp sensors on a P4? I may have forgotten to mention that.
So thanks, I think I'll refrain from trying to stick it in between. I think otherwise I'll just use the side of the heat spreader, you can still easily access it under the block.
Who needs a real doctor when you got my machines and their scary needles?
Old February 4, 2011, 05:34 PM
krazyups's Avatar
IIRC, they're on-die, under the heat spreader and inaccessible.
Old February 5, 2011, 04:15 AM
KaptCrunch's Avatar
yes on die thermoressistors is the way to go with speedfan,real temp are some apps out there
or for spot temp cheaper
Old February 5, 2011, 09:03 AM
Reyzac's Avatar
Thanks for the info guys, I'll see if I can get readings from the temp sensors on die.
Old February 6, 2011, 11:19 AM
Originally Posted by LarkStarr View Post
what in the world.. why..?
you can't just run a thermocouple between a chip and a heatsink, that will mess up the heatsink entirely unless you drill/etch out a channel in the heatsink.. but then you're just going to be measuring that specific area, not the entire chip.
I'd find a way to measure the exhaust temperatures. that's your best bet with something like that. stick it in between a heatsink fin somewhere not too close to the fan..
what's wrong with your onboard CPU temp sensors?
and yes, flattening the ball will likely mess up the probe.
CPU temperature sensors aren't very accurate and are totally useless when you go below 10C on the CPU. If you are an extreme bencher or using the power of the Canadian Outdoors you might want to even have a rough idea of your CPU temperature.
Old February 6, 2011, 11:30 AM
Reyzac's Avatar
Below 10C is not going to happen. The sensors will be fine for my application, and I still have the thermocouple just in case.
HELP Q6600 @ 2.4 stock - Speedfan and Asus Probe alerts CPU @ 119*C CoolHandL CPU's and Motherboards 6 April 22, 2010 07:09 PM
Asus Probe II and Core Temp Dave510 Troubleshooting 4 March 11, 2009 06:35 AM
thermaltake temp probe on/off elninio Water Cooling 2 June 9, 2008 09:23 AM
T-line with temp probe flclisgreat Water Cooling 7 May 10, 2008 11:30 AM
