Old January 31, 2011, 07:20 AM
Varroa's Avatar
Default Water block for 6950?
Hey Guys, picked up a reference 6950 2GB card (XFX) and wanted to know what full coverage waterblocks work with this bad boy. Can I use a 6970 block? I know the Koolance FC block works on both the 6950/6970 but what about the EK blocks? I was at Dazmode and he has 3 different EK 6970 blocks available. What is the difference between the two acetal blocks? Thanks
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old January 31, 2011, 09:01 AM
Varroa's Avatar
I was able to answer my own question and I ordered the EK 6970 block, thanks.
Old January 31, 2011, 09:13 PM
Yeah, all reference boards right now work with the 6950/70 blocks. The neutered version2's aren't in the retail channel yet, and have a different VRM layout which will not work with reference blocks (tho some are being made with a changable VRM coldplate).
Old February 2, 2011, 12:03 PM
Varroa's Avatar
Yep, I can confirm this. I am rocking a EK 6970 block on my new 6950 and it works great! Idle GPU temps are 23c and load temps so far have not gotten over 40c. Not sure about the VRMs yet since I cannot figure out which value in GPU-Z are the VRMs.
Old July 7, 2011, 10:34 AM
Trial Member
can you confirm that the EK 6970 works with the XFX 6950 2Gb? Because i have already ordered the wrong water block once.
Old July 7, 2011, 11:08 AM
lowfat's Avatar
XFX always uses reference designs so it should fit. Although I honestly haven't kept up so I am not sure if different revisions of the HD6950 were released or not.
Mael
Big Lian Li
Forever Alone
Old July 10, 2011, 09:03 PM
Hey there, I am planning on WC what I believe to be the same card and I was just wondering if anyone knew if this card has any available waterblocks? ImageShack® - Online Photo and Video Hosting ImageShack® - Online Photo and Video Hosting
Any help would be greatly appreciated!
Old July 11, 2011, 04:10 AM
Alberto...you can submit a " new hardware for compatibility check " through EKWB's Cooling Configurator webpage, upload images of both the front and back of the videocard in question, along with a link to the manufacturers product page.
CoolingConfigurator.com
As both AMD and NVidia partners (other manufacturers of AMD and NVidia videocards) will often take a reference design then change it to suit their own, it is especially difficult for water cooling companies (such as EK) to keep up to the changes.
This is why EKWB has the "Cooling Configurator" page (and subsequently the "submit new hardware" form) to check if the card in question is physically (or just visually) compatible with any of their waterblocks.
Hope this helps.
B.
" If I had a dollar for every time I heard "My God! He's covered in some sort of goo, " I'd be a rich man. "
Homer J. Simpson
Old July 11, 2011, 04:31 AM
Hope this helps.
B.
I have indeed submitted a new hardware form but instead of waiting I wanted to see if anyone already had an answer :P I really want to order the parts already :)
Old July 11, 2011, 07:35 AM
Beware there is a revised 'reference' that xfx refers to as v1.1, and unless you got the card from December > Jan / Feb you most likely will have the revised 'reference' model.
gpu water block CTA Water Cooling 9 December 24, 2010 10:59 PM
HD5870 water block micul Water Cooling 4 August 12, 2010 08:09 PM
[WTB] 5870 water block. kyle_L Buy/Sell & Trade 3 May 2, 2010 12:32 PM
Best Water Block for i7 Bubbzilla Water Cooling 7 July 7, 2009 11:54 PM
EK Water Block miggs78 Water Cooling 20 October 12, 2008 06:13 PM
