  #21 (permalink)
Old February 1, 2011, 10:17 PM
SneakySnake's Avatar
How do your temps look now?
i5 8400 || Strix 1080 Ti || 16 GB DDR4 3000Mhz
  #22 (permalink)
Old February 2, 2011, 12:54 AM
4Ghz Prime95 for 1 hour like 75-78.....i think that pretty solid
idles at like high 30's low 40's
i7 920 D0 @ 4ghz
Custum WC Loop
Asus P6X58D-E
6 Gb Corsair 1333
EVGA 760 GTX
NZXT Phantom
  #23 (permalink)
Old February 2, 2011, 01:36 AM
MonsterSound's Avatar
Glad you figured it and and posted about it too. That was a head scratcher and now we know.
Code:
 my Heatware,  RFD &  eBay
MAIN: i5 3570 @ 4.5Ghz wH100 / evga GTX780 SOC / MSI Z77A-G45 / 8gb G.Skill 2133 1T / 30" 2560x1600 / Antec P280 / PCP&C 950w / Intel 520 SSD 240gb / Eclipse / G3-Lazer / z5300 / Win7 Pro64 / APC Xs1300
HTPC : nMedia6000B / AMD X2 4400+ / M2A-VM / Corsair 4GB 800 / LiteOn Blu-Ray / 8800GT / Samsung 46"LCD / 2x2TB / OCZ500 / ATI550 / Wrless Kbrd & Rmte / z-5500 / Win7Pro / APC700
"You must be the change you want to see in the world"
- Mahatma Gandhi
  #24 (permalink)
Old February 2, 2011, 06:04 AM
Rison's Avatar
Originally Posted by MikeFallen View Post
So you all can have a good chuckle i figured out that my push pull config wass really a push push config ......some i managed to put both fans blowing at each other .....';
But im happy i figured it out .....
That's awesome.
Corsair recommends to have the fans intake to the case.. which I still don't understand. I would recommend (as well as others) to have the fans (both!) exaust out the back. Reason being = not to have hot air blowing inside the case and raising your motherboard / internal temperatures.
The difference in cpu cooling is marginal, 1-2c at most.. assuming you have decent air flow in your case already.
I'll learn to manage my anger, when people learn to manage their stupid.
  #25 (permalink)
Old February 2, 2011, 07:09 AM
Arinoth's Avatar
Well i'm glad to hear you figured it out, seemed like it would have been something silly like that. Its why i asked the original stupid question if your pump was plugged in, i should have asked what your fan configuration was.
Here I am: here I remain
  #26 (permalink)
Old February 2, 2011, 11:20 AM
yupp i have both fans exhausting out the back now works great
i7 920 D0 @ 4ghz
Custum WC Loop
Asus P6X58D-E
6 Gb Corsair 1333
EVGA 760 GTX
NZXT Phantom
40 TB Media Server Performance issues ashrafi Storage 10 February 3, 2011 06:34 PM
MLC High Performance SSD-CORSAIR Performance Series 128GB PC/NB Dual Platform Test windwithme Storage 2 April 10, 2010 07:44 AM
[FS] Corsair H50 mattlef Buy/Sell & Trade 1 January 8, 2010 06:18 PM
