Old January 27, 2011, 06:07 AM
Prolab's Avatar
Default Dual loops or no?
Hey Guys,
Im finally close to WC my rig, im just missing my tubing and fans. But most of the parts are either here and/or on the way. Anyhow, my dilemma...
I have 2 pumps. A MCP355 w/ XSPC and a 655 vario w/ EK D5 v.2 .
I am planning to WC both my CPU and GPU with 2x 320 swiftech rads. So my question is, would i benefit having the 2 seperate loops? Or just stick with the 655 or MCP355 and keep the CPU and GPU in one loop?
Gaming Rig:
-Caselab STH10, Swiffy MCP35x2, (2) Aphacool UT60 480 rad, HWL GTX 360, Heatkiller IV, i7 5930k @ 4.5 Ghz, 16GB Ripjaws, Asus X99 Deluxe ii, (2) XFX R9 290 w/ XPSC WB, 240 GB Intel 530, 500 GB 850 EVO, (6) 3 TB Tosh HD, EVGA G2 1300 PSU, Win 10 Pro
HTPC Rig:
-G3258 @ 4.0 Ghz, Asrock Z97 Pro 4, Asus 290, 128 GB Crucial M4, (2) 2 TB WD Green, (1) 2 TB Sammy F4, (2) 5 TB Tosh HD, Enthoo Primo, XSPC 480, 240 HWL GTS, Corsair HX620, Win 10 Pro
Old January 27, 2011, 06:31 AM
Given your specs... I'd probably go with single loop, unless you plan to crossfire another 6950 than I would go dual.
Old January 27, 2011, 07:06 AM
matsta31's Avatar
I would do single to. Even your cpu + GPU on one Radiator is ok, so One loop.
Sold hardware again.....
Currently using WHS hardware....
Old January 27, 2011, 07:15 AM
I'd keep the more powerful 355 and put everything in one loop. Sell your 655 for some cash as having a dual loop wouldn't even hurt your temperatures.
Old January 27, 2011, 08:03 AM
gingerbee's Avatar
from what other members have said ( who i trust there judgement ) have told me many times that it just a waste and now you have 2 loops to clean and worry about. my2cents
Old January 27, 2011, 10:31 AM
655 + single loop is the best bet dont even bother with dual loops temps arent really any better either i mean hell were talking temps on an i7 around 50-60c and gpus maybe around 55c on average 2x 320 rads is excessive and not even needed a 240mm rad is usually enough for CPU + GPU loop a single 320 rad is also just fine if you feel like using both 320mm rads go for it it wont make temps magically any better but wont hurt either and besides i guess the E peen bonus is worth it to
Old January 27, 2011, 11:19 AM
One loop with one rad should cool your setup fine!
I've had an i7 @ 4.2 GHz, Radeon 5870, Rampage 2 Gene motherboard block, all on an MCP355 + Swiftech 320 with 3xS-Flex@1000RPM with reasonable temperatures.
heatware
Old January 27, 2011, 11:46 AM
Yeah definitely stick with the 355.
Here is some information on pump power (Higher is better):
Head Pressure in PSI at 1.0 GPM of flow (3.8 L/Min)
MCP355 + XSPC Top: 6.40 PSI
MCP655 + EK Top: 4.95 PSI
MCP655 Stock: 4.72 PSI
MCP355 Stock: 4.63 PSI
MCP350 + Top: 4.48 PSI
DCP 4.0 Stock: 3.83 PSI
XSPC 750: 3.59 PSI
MCP350: 3.25 PSI
As you can see the 355 + XSPC Top is easily the most powerful pump available.
Old January 27, 2011, 12:00 PM
lowfat's Avatar
XSPC 750: 3.59 PSI
MCP350: 3.25 PSI
Head pressure isn't all that important in a sealed watercooling loop. The difference in flow rate between a D5 w/ a top and a DDC3.2 w/ a top is almost nil. Plus the D5 is quieter and has the option to slow down the pump.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old January 27, 2011, 12:13 PM
Head pressure does matter, however it's simply a question of whether or not you have enough of it. For the simple loop listed in the OP, either pump would have enough head pressure.
I don't really find the noise produced by the 355 to be a concern, as 1350 RPM yate loons are much louder than it. Additionally, the 655 consumes more power than the 355.
Slowing down the pump is a moderately useful feature, mainly useful for bleeding. (Any setting below 4 is just so weak as to be useless for everyday use).
All in all it's the OPs decision. They are both great pumps, I prefer to the 355 but either of them will work fine for his loop.
I also think he will be able to sell his 655 for a higher price than his 355 because they are a more powerful pump.
When should u change your loops liquid? Dashock Water Cooling 9 April 25, 2010 06:11 PM
Fruity Loops Studio Sounds shayan288 Off Topic 0 January 24, 2009 03:29 PM
Two Loops? Infiniti Water Cooling 10 June 16, 2008 09:32 AM
Suggested loops and Pump silverchair Water Cooling 6 February 23, 2008 10:17 AM
Fruit Loops r00tman CPU's and Motherboards 13 May 4, 2007 07:47 AM
