Old January 26, 2011, 02:48 PM
matari's Avatar
Question Question about installing a motherboard block.
My motherboard is Asus PT6 Deluxe. I have the EK-FB Asus x58 and Mosfet blocks. My question concerns the application of thermal paste on the north bridge. What method does one use?
Old January 26, 2011, 02:54 PM
lowfat's Avatar
Just place a little drop of the thermal paste in the center of the chipset. It will even out when the block is mounted.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old January 26, 2011, 03:18 PM
Basically your goal should be to put as little TIM as possible onto the NB. The chip is so small any amount of thermal paste will provide adequate coverage. Putting too much on will hurt temperatures.
Change motherboard without re-installing..possible? Mark CPU's and Motherboards 4 July 1, 2010 08:16 AM
installing a Ek Water Blocks EK-FC4890 CF Nickel Full Cover Radeon HD 4890 GPU Block bc_tileguy Water Cooling 7 July 7, 2009 03:59 PM
Question about Noctua NH U12P SE 1366 (Nickel plate, installing both fans issue) appplejack Air Cooling 5 January 13, 2009 01:44 PM
installing a motherboard Defiant CPU's and Motherboards 8 December 17, 2008 01:38 PM
Question on installing OCZ Vendetta tao5269 Air Cooling 4 May 1, 2008 07:07 AM
