Old January 8, 2008, 08:05 PM
Default Cooling Dilemna (CM690)
I have a CM690, and here is two possibilities :
1 - TRUE and only 1 side fan
2 - Ultima-90 and 2 side fan
Which combination is better?
Edit : Ultima-90 and not the ultra-90
Back up - Ebay (Inik1) or Heatware
Old January 8, 2008, 08:10 PM
2 - Ultra-90 and 2 side fan
Well the 690 has two holes on the side panel for
A) CPU
B) Video Card
C) More air
Which do you want? :P More CPU cooling, more video card cooling, both are all the above?
I have no fans on that side and have flipped the panels so the 2x120 holes is on the back side and my cpu still idles at 40' with the fans i have setup.
Old January 8, 2008, 08:16 PM
I think I'll try the second option with the Ultra-90
The heatsink is still performing well..and with a NF-P12.. it should be enough to get a decent oc with decent temps
Swiftech H20-220C + Coolermaster CM690 = Pump Noise! Arrgh! Nate_The_Great Troubleshooting 2 January 22, 2008 01:58 PM
