Old January 5, 2011, 10:35 PM
Originally Posted by Jackquelegs View Post
Think harder
Yes. It works very well the way he has it setup - so long as the restriction in each block is equal it will split 50/50. Since his blocks are the same (correct me if I'm wrong) it works flawlessly. I've done this in 3 way SLI and 2 way crossfire and temps have been pretty much the same both both cards.
Old January 5, 2011, 11:01 PM
sukebe's Avatar
nice set-up Jackquelegs. What are you using to connect you gpu blocks? and where did you find white sata cables?? The cables i have now are rainbow color
Old January 5, 2011, 11:18 PM
Jackquelegs's Avatar
NCIX.com - Buy Koolance Adjustable Dual VID Connect Nozzle for SLI or CrossFire Cards with One Slot Spacing - CNT-VDA2 In Canada.
This to connect the blocks (be careful when you use them, they don't come with a manual :P)
White SATA cables were from years ago under this
NCIX.com - Buy nGear Serial ATA SATA Left Angle Cable 18IN 7PIN - RC-SATA-LEFT18 In Canada.
The color they give seems to be random. I got a batch of 7-8 whites
Iapetos
Zephyranthes
Adding a 2nd rad and pump - series or independant?? TALON Water Cooling 10 August 14, 2010 10:51 PM
Corsair Adding 256GB Extreme Series SSD FiXT Press Releases & Tech News 0 August 25, 2009 10:36 AM
Adding a second card to my loop? nasrott Water Cooling 10 July 15, 2009 07:04 AM
Series VS parallel: tri-fire watercooling vinister Water Cooling 4 May 2, 2008 05:47 PM
anyone know about "SERIES-PARALLEL COMBINATION CIRCUITS"? Shadowmeph Off Topic 4 November 16, 2007 02:05 PM
