Old January 5, 2008, 11:22 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Default Thermaltake TMG A1 Review Comment Thread
AkG's review of the Thermaltake TMG A1 has been posted. While it is a good cooler, there are a number of points that Thermaltake could have improved upon.
Check out the review here:
Thermaltake TMG A1 AM2 CPU Cooler Review
Old January 6, 2008, 06:21 PM
MpG's Avatar
MpG MpG is offline
Level up: 44% Level up: 44% Level up: 44%
Level: 15 - 365 points to level up
Very nicely done review. It doesn't work on anything I own, but informative nonetheless. Nice to reminded that Thermaltake DOES put out some solid stuff alongside its colour-blind bling.
One little thing I noticed - the last con in the conclusion is missing a fairly important word: "Fan does NOT move enough air to be effective at higher Thermal Loads".
QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB
Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB
Old January 6, 2008, 06:49 PM
SKYMTL's Avatar
Thanks. Fixing as we speak.
Old January 6, 2008, 08:04 PM
Level up: 97% Level up: 97% Level up: 97%
Level: 16 - 28 points to level up
Looks like a lower quality Arctic Freezer 64 Pro...
Anyways, good review as usual.
Xeon Quad X3350 | 3.40GHz (Damn X38 chipset)
ASUS Maximus Formula | BIOS RF0410
2GB Corsair Dominator | 850MHz
[/font]4-4-4-12-2T
2GB OCZ Platinum Rev2 | 850MHz 4-4-4-12-2T
HIS ICEQ4 Turbo HD4850 @ 700/1200
X-Fi XtremeMusic
Antec TruePower Quattro 850W
Antec 900
[ HEATWARE ]
Old January 12, 2008, 06:09 PM
Amon's Avatar
It's height should also be noted. Unlike Scythe coolers, this heatsink's standoff height from the processor and motherboard make installation effortless and prevents dust buildup.
But those aluminum fins are so few and cooling performance suffers as a consequence....
**Defunct** Socket 939 San Diego 4000+::2GB PC3200::Radeon 9600 SE 128MB::200GB HDD::24" Dell 2407WFP-HC::WinXP x64/x86 dual boot
Dell Vostro 1500 laptop::Socket P Merom T7100::2GB PC5400::Go 8600m GT 256MB::660GB HDD::15.4" WXGA+, 24" Dell 2407WFP-HC::WinXP
Old January 16, 2008, 09:14 PM
first page, second paragraph, second line: should say "quite", not "quiet"
properly spelling the wrong word doesn't count!!!
second page, first line, should say: "may be", not "maybe"
second page, bottom paragraph: "its", not "it's"
third page, first paragraph: "copper and metal"? copper IS a metal. i assume you meant "copper and aluminum"
ditto for the paragraph under the pics of the copper+"metal" base
page four, second paragraph: should say "allow it to mount to the cooler"
page four, paragraph four: "it does pay..", not "its"
good heavens, i'm less than a third done reading... i'll add more "comments" if you'd like
Nothing's out there. All there is is sea, and birds, and fish. And 20,000 tonnes of crude oil. And a fire. And the part of the ship that the front fell off. But there's nothing else out there - it's a complete void. The environment's perfectly safe.
Thermaltake Sword M Review Comment Thread SKYMTL Cases 20 February 10, 2008 01:11 AM
Comment Thread for Thermaltake TMG ND5 Review SKYMTL Video Cards 5 October 25, 2007 06:11 AM
Comment Thread for Thermaltake Purepower Rx 600W PSU SKYMTL Power Supplies 7 October 2, 2007 09:31 AM
Edifier S5.1 review Comment thread Robscix Audio 3 August 4, 2007 03:52 PM
Comment thread for Thermaltake Soprano DX review Wankerfx Cases 2 June 25, 2007 09:53 AM
