Old December 22, 2010, 03:41 PM
jtf2's Avatar
Default hard mount from cpu to chipset block
quick ?,what are the exact bitspower fittings used in this pic,that is from sidwewinders computers
thanks
Old December 22, 2010, 04:09 PM
SugarJ's Avatar
Looks like 2 triple rotary 90's, and a male-male adapter.
It could also be 1 triple, 1 double, and an anti-twist.
Old December 22, 2010, 04:18 PM
jtf2's Avatar
thanks.
i think that might be a m-f adapter sitting on the base of the ek block also,in the middle i think either a dlpug,or a m-m rotary adapter
Old December 22, 2010, 04:26 PM
Looks sexy but in terms of maintenance it will be a PITA. What happens if you want to upgrade your CPU? ):
heatware
Old December 22, 2010, 04:32 PM
dustin1706's Avatar
I did the same thing from my R3E to my EK supreme HF. I am assuming you are getting the EXACT same board and waterblock as in the pic. The same combo of fittings obviously won't work on other setups. I ended up having to use a bunch of m/f extensions to get mine to work.
A triple, a double and a twister. OR 2 triples and a m/f (same difference).............. Or it could be a combo using 2 single rotary snakes and a bunch of m/f but why would you do that lol.
From the pic it COULD be a m/f 2 doubles and a twister, but then you will have to remove the waterblock to install / uninstall the fittings. If you do a triple, double and twister (or triple triple m/f), to install it you just screw moth sides down simultaneously.
Bitspower Shining Silver G 1/4 Anti-Twist Adapter - # BP-DR-C
Bitspower G 1/4 Shining Silver Triple Rotary Angle Fitting - # BP-90R3
Bitspower G 1/4 Shining Silver Dual Rotary Angle Fitting - # BP-90R2
Bitspower Shining Silver Rotary Mini Snake-Style Adapter - BP-MSR
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
Old December 22, 2010, 04:44 PM
jtf2's Avatar
yes i already have the e760,and the hk 3.0 block
i tried this once before with a rampage formula and a bitspower nb block,and the two pieces i could not end up getting connected-the height difference was too great.
Old December 22, 2010, 04:47 PM
dustin1706's Avatar
hehe. You just need to use a bunch of different sized m/f fittings. i have about 7-8 different fittings in my "bridge"
Old December 22, 2010, 04:54 PM
jtf2's Avatar
bitspower now have some new different length extenders
Reducers & Extenders : Performance-PCs.com, ... sleeve it and they will come
which could prove useful
Old December 22, 2010, 05:17 PM
gray mole's Avatar
WOW
I wish that stuff was around when I was watercooling.
One of the reasons I went to the small pipe, and then eventually just stopped using water, was the mess you'd end up with. It's not 'terrible' when you have the run of pipes or anything, just ends up looking 'thrown together'.
This setup is about as nice as I've ever seen. That, and in a solid setup the worry of leaks from vibration are pretty small too.
I'll be setting up a tower at some point soon and while I have a phase cooler in mind for the cpu (of course) I might have to rethink my views on water for the rest.
Looks like modern watercooling has come a long way :D
I like the cold...
Old December 22, 2010, 08:30 PM
SugarJ's Avatar
I've changed my mind. It's a triple rotary, a mini m/m, a double rotary, and an extender.
Directcanada, XSPC X2O Universal Chipset Water Block Black Delrin Top G1/4 Mavvens Water Cooling 9 July 18, 2009 06:59 PM
EK is going to release EVGA Classified full cover chipset block Dazmode Water Cooling 14 June 17, 2009 07:16 PM
[WTB] WC parts (pump, res, tubing, chipset block and 4850 compatible GPU block) donimo Buy/Sell & Trade 5 February 2, 2009 12:53 PM
Where to buy backplate mount for my cpu cooler? mailaw Air Cooling 4 January 13, 2009 07:39 PM
