Old December 17, 2010, 12:17 PM
Default should I upgrade my loop?
Well, I have been using this for 2 years on a core2quad x3210. I have a swiftech 655, swiftech mcr220 rad, and apogee gtz. I have an order being shipped to me right now from NCIX with my new case (haf x), mobo (asus p6x58d-e) and ram (gskill ripjaws 1600) and im almost regretting not buying a new cpu block and rad while I made the order. I guess Im going to hook it all up when it gets here but would I really notice much of a difference from a new cpu block and a 120.3 rad? I only cool my cpu.
*edit* I forgot to mention I already have my i7 970. Which I will obviously be overclocking.
Old December 17, 2010, 12:25 PM
gingerbee's Avatar
I didn't and i just bought a 1156 bracket to go on my gtz and it didn't make a difference that much on my 920's so why would it make a big one on my 1156's. my2cents
Old December 17, 2010, 12:42 PM
I have a bracket already for the 1366 socket. It came with my gtz. Which was nice. I guess I will hook it all up and test it. If I dont get temps I like I can always upgrade. I really like the look of my cpu block. I havent got my case yet but if I can somehow manage to internally mount 2 rads I might just try it. I guess that will be a project for the new year. Lets just see how this goes for now. Dang ground shipping is taking forever.
Old December 17, 2010, 12:49 PM
Probably not with the block... blocks on the market today are within a degree or two of each other... only thing that differ is the flow rate some blocks may have versus others.. the increase in radiator size would probably be your best upgrade... if you were to choose from the two...
Old December 20, 2010, 01:44 PM
Dazmode's Avatar
I would upgrade if you like newer fresh look, not for major performance breakthrough.
Orange Build: Final Video
HTPC Build: Final Video
Old December 20, 2010, 03:36 PM
:-) yeah I just recently upgraded for partial looks & partial performance. guilty!
Old December 20, 2010, 04:06 PM
Fudd Rucker's Avatar
How is that new TFC working out for you?
I couldnt think of something snarky or interesting to put here this time around.
Old December 20, 2010, 05:50 PM
Required a little cleaning but after that it was all good... added it to my singleloop.. currently sitting at the bottom of my corsair 700D :-D.
How's the RX360?
Do I have everything I need for WC loop? ADay2Long Water Cooling 15 August 6, 2010 09:34 PM
Another loop order, single/dual loop thread... turtletrax Water Cooling 8 July 28, 2010 08:40 PM
VGA upgrade from GTX 260 first, or CPU+mobo upgrade first? panzerfan Video Cards 9 April 6, 2010 08:25 PM
Loop help Lpfan4ever Water Cooling 12 September 22, 2009 06:22 PM
My Soon-To-Be loop Kopi Water Cooling 5 October 23, 2007 12:49 PM
