Alright, well, I'm a bit new here at HWC, but I'm quite active over on the NCIX forums under the name Jonathon.
I've decided that in the new year, I'll be water cooling. I've done a lot of research over the past month, which has lead me to get a couple components already. I do however, have some questions for the HWC water cooling community.
I'm running an i5 750 right now, along with a GTX 470. The plan is to move to an i7 870, due to slightly better multi threaded performance, and I do like "playing around" with things like virtualization and video encoding. Having those extra threads should help a fair bit. I picked up a few used components over the past few days, namely an MCP355 w/ EK x-top revision 2, some Bitspower true silver 1/2" barbs, and a TFC X-changer 360. The rest of my components will be purchased in January, unless I come across any good deals in the time being.
My planned purchase for January will be an EK Supreme LT water block, tubing, and a reservoir of some sort, along with some hose clamps.
All of my components are currently residing in a HAF 932, and I do hope to keep it that way for now. I also have 6x Noctua NF-P12s that I plan on mounting to the radiator in push/pull. So, onto the questions...
1. For the Supreme LT, would it be wiser to get the nickel plated version, or just stick with the copper?
2. Would the Feser 360 handle the heat load of a 4+GHz i7 870 AND a GTX 470 with a full cover block?
3. Tubing. Suggestions on brands, and since I'm using 1/2" barbs, I would assume 1/2" tubing, but I've read of better fits and whatnot with smaller tubing. Would 7/16" or 3/8" work better? I'd also like to keep the tubing black or white. It'll go with the P55 FTW.
4. Would push/pull Noctuas perform alright on the radiator, or should I shop for different fans? I'd like to keep sound to a minimum, or at least keep the sound signature as close to what it is now as possible.
5. How would one mount push/pull fans on a radiator? From what I can tell, the radiator only comes with enough screws for 3 fans. Would there be a specific place to order them, or would I be able to obtain compatible screws from a hardware store?
6. Reservoir suggestions? I'd like to keep the loop as clean looking as possible.
7. Angled fittings. Is it alright to use one or two right angle adapters in a loop, or would it cut flow too much?
8. Mounting for the MCP355. I have read that it does produce a fair bit of heat. What would be the best way to mount this while keeping vibrations to a minimum?
Thanks a lot in advance, I just want to make sure everything goes smoothly for my first loop.
