Old December 13, 2010, 12:31 PM
KaptCrunch's Avatar
Default Laing Pumps that shake/vide
doing a poll on your laing pump any model
just want to know the % of noisey viber units
Old December 13, 2010, 12:32 PM
gingerbee's Avatar
i have owned 3 and none made noise at all i that found
Old December 13, 2010, 12:39 PM
matsta31's Avatar
I owned, through the last 4 years, about 4 different Mcp355. One was vibrating.... The ifrst one actually. I dont know if it was a case/position thing or the pump. I corrected the problem by using a small piece a material to dampen the vibration.
Sold hardware again.....
Currently using WHS hardware....
Old December 13, 2010, 01:27 PM
JayDeeHobbit's Avatar
Not a peep of noise or jiggle of vibration from mine.
MCP655-B I've had for 3 1/2 years now and has been going 24/7 for about half that time.
"Try looking into that place where you dare not look!
You'll find me there, staring out at you!" - Frank Herbert
Old December 13, 2010, 02:17 PM
G777's Avatar
Had one mcp355 running 24/7 for a year... so far no issues
_______________________________________________
HWC Overclocking Team, breaking hardware for fun!
Team Thread
Old December 13, 2010, 02:57 PM
AmuseMe's Avatar
Mine makes noise, they all do, it's impossible for something that has a motor not too :p But if the noise bothers or is recognized by a person or not, that is different. I have a 355 with an EK top, and find that the noise is moderate. It doesn't bother me at all, and my tower is right beside me. It also doesn't vibratre - its mounted on a homebrew shoggy
DEAD CA$H
Old December 13, 2010, 03:13 PM
gingerbee's Avatar
well i have owned 3x 355 mcp's and 2 655 and the only time they made any noise that was noticeable without putting my ear to them was when priming you know that the fluid rushes around to act as a buffer between the outer walls, there design this way it's how they last so long he he there's no physical motor in them it's a magnet drive alternating current with a ceramic bearing but i am pretty sure you know this man
Old December 13, 2010, 07:14 PM
MpG's Avatar
MpG MpG is offline
Three DDC 3-series, one D5, all excellent. Soft-mounting is required, of course, just like any pump, but no abnormal vibes or shakes.
Old December 13, 2010, 07:51 PM
MCP655 with EK-D5 X-TOP 10 months @ setting 2. No noise.
Old December 14, 2010, 08:03 AM
Dazmode's Avatar
I use 1 x 655-B and 2 D5 vario. Rather quiet for my taste even at max speed. I'm bit deaf on one ear although...
Orange Build: Final Video
HTPC Build: Final Video
Mount Laing ddc Chaltharr Water Cooling 0 January 29, 2010 08:03 PM
Shake Violations on GPU Perineum HardwareCanucks F@H Team 10 October 23, 2009 10:24 AM
[FS] 2 pumps Laing D4 Aqua Xtreme 50oz Primu$ Buy/Sell & Trade 13 April 29, 2009 01:03 PM
2 pumps ? Wasza Water Cooling 10 December 13, 2007 10:17 AM
