Old December 12, 2010, 03:58 PM
Default Distilled Water?
Well I've gotten everything that I need for my loop and I just realized that I completely forgot about the distilled water Where do you guys get yours? and how much would I need for CPU+GPU loop with a quad radiator?
Old December 12, 2010, 04:04 PM
SugarJ's Avatar
Get a gallon at your local drug store or Safeway for about $3. Lots of people use it in their irons to prevent mineral buildup. And my triple rad with CPU/GPU/NB uses less than 1 liter.
Old December 12, 2010, 04:16 PM
martin_metal_88's Avatar
Drug store is the best place as SugarJ said. Be aware, don't drink it ;)
Old December 12, 2010, 04:42 PM
sswilson's Avatar
Why wouldn't you drink it? It's just water with impurities removed.
If you've got a choice, go for the lowest mineral content you can find.
Old December 12, 2010, 05:08 PM
Jackquelegs's Avatar
There will always be people that over-do it.
Iapetos
Zephyranthes
Old December 12, 2010, 05:31 PM
Perineum's Avatar
Distilled water is just pure water. No reason to drink it. Next cleanest would be reverse osmosis cleaned water...
Old December 12, 2010, 05:46 PM
elton5354's Avatar
Shoppers Drug Mart has it for around $1.40 per gallon
Old December 12, 2010, 05:57 PM
As mentioned before no point in drinking it as you don't get any minerals from regular water which is better.
Also, since the water is pure, it is absorbed by the body a LOT faster and can cause cramps, discomforts and what not to some people. That's why it's not recommended to drink.
Old December 12, 2010, 06:16 PM
Perineum's Avatar
Wow.
That is absolute horseshit......
Old December 12, 2010, 06:45 PM
...what the **** are you on about? source?
Question about using distilled water as a coolant matari Water Cooling 12 December 8, 2010 11:24 AM
Water is the best? magictorch Water Cooling 16 January 25, 2009 06:41 PM
Deionized, demineralized, distilled -- which to get or avoid? S_G Water Cooling 10 November 19, 2008 11:23 PM
Distilled water spills can short out computer parts?? Dashock Water Cooling 6 May 5, 2008 11:29 AM
Where the water go... francois methot Water Cooling 10 October 23, 2007 10:57 AM
