Old December 12, 2010, 12:17 PM
Nevakonaza's Avatar
Talking CoolIT ECO question.
So ive just purchased this CoolIT ECO Cpu Water Cooling Kit,Now i know its not considered a "Real" water cooling setup,But its probably the best i can get to it without having to spend a furtune.
Anyway i have a question,Should i mount the Rad at the top of my case with it exhausting the hot air out the top of my case (Coolermaster CM690)?
Or mount it at the rear of the case exhausting?
What would be best?
Old December 12, 2010, 12:28 PM
Rear is best as the fan on the front will help push any warm air out through the rad.
Old December 12, 2010, 12:42 PM
Nevakonaza's Avatar
So thats one vote for rear....i do have a very good 120mm Silverstone fan mounted on the front of my case,Its like a leaf blower :D
Thanks for replying.
Old December 12, 2010, 12:44 PM
Then mount a low speed fan on the roof blowing out and you'll be good.
Old December 12, 2010, 12:55 PM
Soultribunal's Avatar
Yup, thats the best way to do it really. Ena's suggestion really works best. I've used two now.
ST
Old December 12, 2010, 01:00 PM
as long as its exausting and not fighting with another fan close by for the volumes? whatever floats your boat :)
Old December 12, 2010, 01:02 PM
Nevakonaza's Avatar
Awesome thats what il do then,Ive actualy got a spare 120mm fan so i can put two fans on the rad,One pulling the air and the other pushing it out the back of the case.
Il try it out anyway see what happens :D
Thanks guys.
Old January 1, 2011, 02:41 PM
Default Radiator Mounted on Top Exhaust
Here is a link to CoolIt Systems forum about the question put to this forum:
Radiator Mounted on Top Exhaust - CoolIT
" There is a small air bubble which we want to trap inside the upper tank. By "flipping" the assembly, so the coolant lines will be at the top, will allow the air to be drawn into the liquid loop and travel through the pump. This makes the pump noisy. "
If you would like to read more forum topics about the CoolIt ECO and their other products, here is the link for that as well
Product Support - CoolIT
" If I had a dollar for every time I heard "My God! He's covered in some sort of goo, " I'd be a rich man. "
Homer J. Simpson
H50 vs Coolit Systems Eco headsh0t Water Cooling 27 August 27, 2010 06:40 PM
Coolit eco vs h50 vs h70 dosmond Water Cooling 1 August 25, 2010 03:13 PM
Corsair H50 vs CoolIT ECO Flemminr Water Cooling 11 June 28, 2010 05:02 AM
Coolit Eco - Should I, or shouldn't I? cul8erppl Water Cooling 4 May 31, 2010 08:15 PM
