Old December 10, 2010, 01:58 AM
Default My water cooling built
finally, after long long time of planning trial and failed my water cooling has finally finished
it wasn't easy, now the last thing left to do is the leak test. give me some thought on what u guys think
Old December 10, 2010, 02:57 AM
chubaka's Avatar
Very clean looking loop.
Thx for sharing
Old December 10, 2010, 07:43 AM
Keywork's Avatar
The amount of fittings make me feel slightly uncomfortable haha. Looks good though! My rig should be up and WC'ed in a week or two as well!
Old December 10, 2010, 08:24 AM
matsta31's Avatar
Great looking rig. Well done sir.
Sold hardware again.....
Currently using WHS hardware....
Old December 10, 2010, 08:54 AM
Supergrover's Avatar
Nice and clean, minimal bends, minimal tubing. Looks good but dont care for the clear tubing but that is just a personal preferance.
Kudo's.
R.I.P.
Old December 10, 2010, 09:03 AM
Dazmode's Avatar
Oh! Limited Edition Supreme! That thing crossed Atlantic twice: Slovenia-Canada-Germany-Canada. Nice build!
Orange Build: Final Video
HTPC Build: Final Video
Old December 10, 2010, 09:13 AM
matsta31's Avatar
Kudo's.
Funny How I only like clear tubing. I find it works better for bleeding etc.
Old December 10, 2010, 09:39 AM
Dazmode's Avatar
Light colored tube is well see through, that is one of the reasons I use Acid Green tune myself.
Old December 10, 2010, 12:20 PM
CTA's Avatar
CTA CTA is offline
are those fittings high resist?
i agreed other about your clean setup...
Old December 12, 2010, 09:06 PM
thanks guys,
apprently i ran into a hiccup with the build
i think the pump is defective as it is not pumping enough water up to the radiator,
thus there is very minimum water going down the cpu block and gpu block
is there any reference on how much water the mcp655 ll pump or how powerful it ll be?
New to Water cooling! Slaughter Water Cooling 53 February 17, 2011 09:26 PM
New to water cooling; need help bkh2 New Builds 31 July 25, 2009 08:02 PM
New to water cooling SquattingDawg Water Cooling 30 July 12, 2009 03:40 PM
new to water cooling jay51 Water Cooling 13 June 22, 2008 03:10 PM
New to water cooling coreyb Water Cooling 14 April 10, 2008 12:55 PM
