Old December 12, 2010, 09:13 PM
gingerbee's Avatar
Maximum head
10 ft (3.1 m)
Maximum discharge
~ 317 GPH (1200 LPH)
Connection size
" barbs
Maximum pressure 50 PSI (3.5 BAR)
taken from here is should easily do your loop Swiftech
Old December 12, 2010, 09:53 PM
Originally Posted by gingerbee View Post
Maximum head
10 ft (3.1 m)
Maximum discharge
Connection size
" barbs
thanks
so judging from the spec does it mean it can push water 10 ft high?
coz i did a mini test, the pump doesn't even pump above 1m , smth is definately wrong here,
but i did'nt think pump break so easily, they 're only like 2 month old
Old December 12, 2010, 11:03 PM
dustin1706's Avatar
Originally Posted by hatabilly0204 View Post
thanks
Yeah, if you disconnected it from your system and gave it a test it should pump fluid to a height of 10 ft ( equivalent to ~4.33psi).
Unless your reservoir isn't feeding the pump, it must be a bad pump. Bummer. I have 3x 655s and they all work great.
That being said, your rig looks great. I really dig the Chrome/clear on black. Also, great idea on the drain port.
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
New to Water cooling! Slaughter Water Cooling 53 February 17, 2011 09:26 PM
New to water cooling; need help bkh2 New Builds 31 July 25, 2009 08:02 PM
New to water cooling SquattingDawg Water Cooling 30 July 12, 2009 03:40 PM
new to water cooling jay51 Water Cooling 13 June 22, 2008 03:10 PM
New to water cooling coreyb Water Cooling 14 April 10, 2008 12:55 PM
