Old January 1, 2008, 02:40 AM
Infiniti's Avatar
Default Water not moving
Well I kind of messed up my watercooling setup... pump->reservoir->CPU->rad->pump and my problem is that when I try and fill the system, all the coolant stays in the reservoir. Is there anything I can do except changing the location of things?
Old January 1, 2008, 03:06 AM
should be
resevoir -> pump -> cpu -> rad
Old January 1, 2008, 03:08 AM
Infiniti's Avatar
Aww... Is there anyway I can drain the system easily and without leaks? I always get leaks when draining
Old January 1, 2008, 03:12 AM
well the resevoir should be flowing into the pump isn't it?
Old January 1, 2008, 03:22 AM
Infiniti's Avatar
Yeah
Old January 1, 2008, 03:36 AM
Yeah
then you probably have to prime your pump; have you done that?
Old January 1, 2008, 08:35 AM
Babrbarossa's Avatar
I'm sure you probably have it right, but I did this the first time: I reversed the "IN" and "OUT" hoses on the reservoir, and the water wouldn't move through.
Old January 1, 2008, 05:50 PM
Infiniti's Avatar
I took out my reservoir and now im using a T-line. Does anyone know how to easily get the danger den tubing plug 1/2" into Swiftech 7/16" tubing? im having trouble And should I get my rad RMAed? Some of the heatsink fins are twisted. Its only one fin in a little spot though.
Old January 1, 2008, 05:56 PM
sswilson's Avatar
To get smaller tubing to fit onto a larger fitting, dip the tubing into a a cup of boiling water.
As far as slightly bent fins go.... I had a couple slightly bent on my 360 and didn't worry about it.
Old January 1, 2008, 06:00 PM
Infiniti's Avatar
Ok thanks. I tried the dipping in boiling water method, but it still didnt work
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 10:22 PM
Where the water go... francois methot Water Cooling 10 October 23, 2007 10:57 AM
Internet security moving toward "white list" @ CBC.ca sswilson Reviews & Articles from the Web 1 September 17, 2007 09:04 PM
