Old January 1, 2008, 09:18 PM
You probably have the Pump connected backwords, I did that and the water would not move from the "T" line, switch it around and it worked like a charm.
"T" line - pump - rad - GPU
Make sure you have the right connection for th "in", "out" on the GPU.
You should be able to fit the 7/16 tubing on the 1/2 connectors.
I managed to connect 3/8ID tubbing to 1/2OD connectors, I boiled a pot of water and used it to soften the end of the tubing.
Hope it helps
AMD Phenon II X4 965 3.4Ghz
Motherboard: Asus M4A78-E
Memory: Kingston HyperX 4GB DDR2
Video Card: Nvidia 8800GT
Harddisk: 2 x Western digital
CD/DVD Drive: Asus
Monitor: LG Flatron W2353V
Case: Thermaltake Armor
Sound Card: Sound Blaster Audigy
PSU: Thermaltake TWV 500W
Software: Windows 7
Old January 1, 2008, 09:46 PM
3.0charlie's Avatar
Originally Posted by Infiniti View Post
Ok thanks. I tried the dipping in boiling water method, but it still didnt work
Do it again, it's the only way. And it has to be boiling water, and dip for 10 seconds.
It's a tight fit.
Hydro-Quebec is salivating...
Old January 1, 2008, 09:57 PM
Wankerfx's Avatar
Originally Posted by enaberif View Post
should be
resevoir -> pump -> cpu -> rad
In my opinion, it should be:
Pump => Radiator => CPU => Reservoir
That way, the heat from the pump will be cooled by the radiator, and the coolest water will hit the CPU.
[ER]
Old January 1, 2008, 10:07 PM
Infiniti's Avatar
Lol my setup right now is Pump->CPU->Rad->T line
Old January 2, 2008, 12:27 AM
My setup right now that im workin on goes . 140x2 rad->D5 Pump->120x3 Rad->D5 Pump -> Gfx Card ->NB-> CPU. Just waiting for the last few parts after a pay check or to then i can put it all back together.
Nice buch of gear- not sure I'd set it up that way though- you're dumping all the heat from you GPU and NB onto you CPU, which is the least heat tolerant, and the most important to overclock- with all the cooling power, you should put a radiator between the GPU and the CPU to have nice cool water entering both the GPU and CPU- run the water through the NB after the CPU.
E8400 E0 4275 (66 hours orthos stable) @ 1.38v 50deg load /Xfx 780i / 4 GIGz Balistix 6400 / Corsair 620hx / 8800gt @ 740/1800/1000 / Water Cooling
Old January 2, 2008, 01:54 AM
Prof. Dr. Silver's Avatar
w00000t! Pictures, Pictures!!!
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old January 2, 2008, 05:08 AM
Babrbarossa's Avatar
Old January 2, 2008, 11:35 AM
I know it would be better to have it as you say but it would make the inside a mess of tubs , the way I have it planed right now is the cleanest way i can have it setup.
Im only aiming for 3.8ghz and with this crapy gfx card i have right now Im not worried about that much heat from the cards . When i do benching it will all be out of the case any way with one of my rads in a buckets of ice .
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 10:22 PM
Where the water go... francois methot Water Cooling 10 October 23, 2007 10:57 AM
Internet security moving toward "white list" @ CBC.ca sswilson Reviews & Articles from the Web 1 September 17, 2007 09:04 PM
