Old December 9, 2010, 10:38 AM
Dazmode's Avatar
This is the balance between fans speed and radiator surface. Dual thick rad with 3k rpm screamers can do a really good job. If you are looking for more balanced noise levels, extra single rad will be handy.
Orange Build: Final Video
HTPC Build: Final Video
Old December 10, 2010, 09:33 AM
Rison's Avatar
I just think people always over-do rads. I tell people I had a 980x oc'd to 4.2-4.3, and a GTX 480SC OC'd to 825++ on a single TFC triple rad.. and they freak out. Then I tell them nothing hit past 52c, and they don't believe me.
I've seen people on overclocker forums putting two triple rads on one 980x, and a triple rad for each video card. To each his own, but that's a waste of money imo. That's not near the case in this OP question.. and I guess adding one 120 rad wont restrict water flow "too much" (depending on how you route the tubing, and if you use any angle adapters) but if I were you (and i'm not) i'd see how a dual rad performs, and upgrade later if it's not to your liking.
I'll learn to manage my anger, when people learn to manage their stupid.
Does Size matter? (smartphones) dustin1706 Mobile Computing 11 February 7, 2011 07:06 AM
aluminum which size? CTA Cases 6 October 20, 2010 11:33 PM
What Stripe Size to Use? catnhat Storage 2 August 25, 2010 10:19 AM
Sleeve size question donkon Guides & How-to's 0 June 27, 2009 11:53 AM
Single rad $$$ > Dual rad $$$ why? frosty Water Cooling 9 July 16, 2008 03:39 PM
