Old December 8, 2010, 09:46 AM
Eldonko's Avatar
Hardware Canucks Reviewer
That's what I meant, same effect. My point was that with a combination of good tubing and silver plating you dont need biocide.
Originally Posted by lowfat View Post
Primoflex tubing is antimicrobial
Old December 8, 2010, 11:01 AM
matari's Avatar
Thanks for all your help. The main reason I am going to stop using EC6 UV Blue is because of Eddy’s pending void of warranty for their reservoirs. There is also a pending void of warranty to be issued with PT-Nuke. Since my whole system (except for barbs and radiator) is EK, I deeply concerned about this action. It seems that distilled and silver kill coil will be my best bet, but there is an issue with using silver and the Multioption Reservoir; microorganism have known to grow in between the threads of the reservoir. So I would like to use something else + the silver kill coil, but I am not sure what there is that is not related to PT-Nuke.
Old December 8, 2010, 11:24 AM
AmuseMe's Avatar
I've got some Feser One stuff in my FS thread :)
Whered all my coolant go?? Realityshift Water Cooling 9 November 16, 2009 09:56 AM
Help With Coolant Additive Johnnyl168 Water Cooling 18 November 29, 2008 05:34 PM
Deionized, demineralized, distilled -- which to get or avoid? S_G Water Cooling 10 November 19, 2008 11:23 PM
Distilled water spills can short out computer parts?? Dashock Water Cooling 6 May 5, 2008 11:29 AM
What is your coolant of choice? Babrbarossa Water Cooling 26 April 14, 2007 07:22 PM
