-   -   Fitting/pump Help (http://www.hardwarecanucks.com/forum/water-cooling/38512-fitting-pump-help.html)
homer98 December 1, 2010 11:50 PM
Fitting/pump Help
Hey all, I was recommended this tubing Primochill Primoflex Pro LRT Black 3/8IN ID 5/8IN OD Tubing (10 Feet) - DirectCanada
So my question is which pump should I get, the MCP655 is what I have heard a lot of people talking about, but it is 1/2inch fitting. How would I use the tubing with this pump? are most pumps 1/2inch? any insight would be awesome. going to start my first loop soon. Getting all the parts together.
Supergrover December 1, 2010 11:56 PM
Primoflex is good stuff but for 1/2 barbs you'll need at least 7/16 ID tubing, soak the tubes inhot water before you slip them on the 1/2 fittings.
You can always buy a top for your 655, that way you get a small performance upgrade and more importantly the choice to use what ever fittings you want be it 3/8, 7/16, or 1/2.
SugarJ December 1, 2010 11:57 PM
One of the problems with buying pumps with fixed fittings is that you sometimes end up buying a top because you want to use a different tubing size. Here's a hint: it's way cheaper to change your tubing size than to buy a custom top for your pump.:thumb:
That being said, EK makes a good top for the MCP655/D-5 pumps: EK-D5 X-TOP - Black Acetal G1/4 Rev.2 EK-D5 X-TOP [EK-D5 X-TOP] - $39.99 : DazMode, Canadian PC Water Cooling and Modding Store
Sidewinder has a larger selection: PC Liquid Cooling Pumps, Pump Controllers, Pump Tops and Dress Kits
Prolab December 1, 2010 11:58 PM
You can buy a top for the 655. Like so:
or these:
Pump Accessories | Page 1 | Sort By: Product Title A-Z - FrozenCPU.com *
There's a lot more tops available for that pump. And you can use whatever size fittings you want on those tops.
homer98 December 2, 2010 12:01 AM
Ok, so what about getting a different pump then? are there some with variable fittings?
SugarJ December 2, 2010 12:03 AM
Sidewinder mods the 655 for $10 over the regular pump, so you can choose your own fittings: Sidewinder Custom MCP655 / Laing D5 with G 1/4 Threads
Or go with the MCP350 or MCP355 pump, they have fixed 3/8" fittings.
Supergrover December 2, 2010 12:06 AM
But it looks way sexyer, ascetics count for alot when doing a loop IMO. And it can offer a lot more flexibility in design of the loop.
http://www.xtremesystems.org/forums/...1&d=1227487637
http://www.xtremesystems.org/forums/...1&d=1227581694
Looks a hella better than the stock 655 IMO.
homer98 December 2, 2010 12:10 AM
Hmm, lots of good options.
**EDIT: Looked at the sidewinder 655 pump with custom threads. looks like that is the way to go.
Supergrover December 2, 2010 12:14 AM
Originally Posted by homer98 (Post 456760)
Hmm, lots of good options. If I do go with the 655, I do like the variable speed control. How would I deal with the other fitting on the pump? If I were to get a top for it that sized it to 3/8" thats all good. but what about the other end of the pump? how would I deal with that since that would be 1/2" correct?
They replace the fittings to what ever you want, 3/8 intake - 3/8 output
homer98 December 2, 2010 12:22 AM
Would you guys still recommend a top? everyone is saying you get better efficiency/performance/aesthetics. Thoughts? and if so, any preferable tops?
