Originally Posted by lowfat Already the property of matsta31
Anyways Pax what fittings are you using? The GTZ works best w/ fittings that do not have a recessed o-ring. |
I was using TFC barbs (one straight, one 45 rotary) from Dazmode. After filling and draining the loop 4 or 5 times due to leaks with the GTZ, I took the o-ring from one of the cheap plastic barbs that came with the swiftech h20-220 I have. I also switched out the the straight barb to a different metal one I had kicking around with a bigger o-ring. The o-rings were a fair bit chunkier and now with those on, it seems to be better.
I should have come back on hwc to check for replies...would have saved me a few headaches, since your little tip was exactly what solved my problems. Thanks :)
And JD, I found some mention of copper (or nickle, can't remember) tops for the GTZ, or GTZ SE, but wasn't able to find the tops for sale anywhere.
