Thermal Paste??? I am thinking of purchasing the Thermalright Ultra 120 Extreme. It also comes with some thermal grease. But should I use that thermal grease? Or should I just go out and buy some Arctic Silver 5 for ~$8? Is there a big difference, or should I just settle with the thermal grease that comes with the cooler? |
I would pay the extra $8.00 for the quality stuff, saves you having to re-do it down the road if the temps aren't to your liking. |
For only $8 I would opt for the AC5. |
Thermalright's grease is one of the better compounds, actually. But switching to AS5 or Ceramique might get you another degree or two under load. Both are easy to over-apply, though. |
Isn't the MX-2 the best one to use right now? I only heard that it takes longer to work in but its better than the old AS5 |
I'm not sure if it's actually much better, but it certainly is on par with AS5, and IMO has the edge due to being non-conductive. |
Hey ppl, I just wrote a review that should be online in a few days..! MX-2 is the better one, not only in performance but also price wise! MX-2 does not have a "curing period" for it's paste. Smear it and use it! sswilson is right...it is actually a little better that AS5! |
| All times are GMT -7. The time now is 01:26 PM. |
