Old December 28, 2007, 07:09 AM
Varroa's Avatar
Default Push/pull
Well, I tried tightening down the waterblock and I added a second fan on the rad (push/pull) and it got me temps under control for now. With the second fan and the waterblock tightend down a little I now get idle temps around 29/30c and under full load (Folding@home SMP or Gears of War PC Game) I get max temps of about 45-46c. Before I tried this I played Gears of War for 10 minutes and my CPU overheated so I think I have found the problem. When I get the backplate I have ordered I am going to re-seat everything and replace the 2 fans on the rad with one higher pressure one. Thanks for everybodies help.
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old December 28, 2007, 07:44 AM
sswilson's Avatar
Good to hear that you've got some improvement.
How's that FX60 working out for you on the Asrock board? I'm assuming that the Dual VSTA bios is similar to the S775 version.... does it have multiplier settings?
Old December 28, 2007, 08:06 AM
Varroa's Avatar
The board is actually pretty good for a cheap board. I was use to enthusiasts (sp?) ASUS mobos before I went to this. This was only suppose to be a stepping stone board since I had a AGP card and wanted to move to a 939 CPU at the time (this board has AGP and PCIe 16x slots on it). The FX is a nice chip and I got it for a steal during the decline of 939 early in 2007.
The board has full overclocking ability but there is not alot of voltage range so your overclocking is limited to within the voltages provided. There is a hack you can do to increase voltages but I never bothered. I know people that have had HUGE FSB overclocking on this board with good ram but I have never had much luck with myself, I think this is due to my ram I am using and the fact that I am using 4 sticks instead of just 2. I have been able to get the CPU to 3Ghz a few times but not for very long. I am going to add a second loop to my system and cool my NB and my HD2900XT when I am sure the first loop is stable. Thanks for the help!
Old December 28, 2007, 08:58 AM
Supergrover's Avatar
When you do get the backplate you might want to consider "bowing" your Apogee as that nets you a few more degrees, make sure that it is oriented the correct way when you do put it back together.
CPU Water Block Round Up APOGEE GT/GTX vs. STORM vs. FuZion vs. APOGEE vanilla
R.I.P.
Old December 28, 2007, 01:50 PM
Varroa's Avatar
Interstesting idea, a little too risky for me but interesting none the less. Thank for the help everybody, when I re-seat everything and re-arrange my fans (after I get back from holidays) I will post my results.
Old December 30, 2007, 03:31 PM
any luck>> I see you posted on the Swiftech fourm... but form what i read there seemed to be no real help..... hope it works out... Im still pondering the purchase of one of these units... wether its the 120 or 220..... im tired of having to stop at 3.2 ghz on my cpu....
i2600k sandy bridge @ 3.4ghz/ 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / G.Skill Ripjaws ddr3 1600 cl 8-8-8-24 - 8gigs / evga z68 SLI MOBO / Samsung DVD+RW / Corsair ax850 PSU / 24" Samsung CinkMaster
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Swiftech Apogee GT Cpu block
Feser One Red Fluid
Old January 3, 2008, 03:54 PM
Varroa's Avatar
Well it looks like it is a combination of not using the correct backing plate (which I now have one) and not using fans with good static pressure. I tightened down the waterblock a bit and added a second fan in a push/pull config and my idle temps dropped to about 39c and under load I get about 46c (using either folding at home smp client or running gears of war pc). My CPU is slightly overclocked as well so I think these temps are now good.
Old January 3, 2008, 04:30 PM
3.0charlie's Avatar
Good to hear that all is back to normal. You're folding for which team?
Hydro-Quebec is salivating...
  #19 (permalink)
Old January 4, 2008, 02:21 AM
Varroa's Avatar
37412 Ncix
  #20 (permalink)
Old January 4, 2008, 09:43 AM
3.0charlie's Avatar
Nah, nah, nah. It's supposed to be 54196!
Swiftech Apogee GT question Vinnie Water Cooling 8 February 23, 2008 03:43 PM
Swiftech H20-120 Compact instock! $132! Cptn Vortex Water Cooling 18 December 2, 2007 03:14 PM
swiftech mcp655 wiring Corpus Masochist Water Cooling 15 September 9, 2007 09:30 PM
don't like the Swiftech micro reservoir Corpus Masochist Water Cooling 10 August 23, 2007 06:30 AM
Swiftech APOGEE Drive JD Water Cooling 14 August 16, 2007 10:35 PM
