  #41 (permalink)
Old February 4, 2011, 12:36 PM
lowfat's Avatar
Buying a $100 fullcover block for a card that only worth $1000 really doesn't make sense. As for universal blocks you are going to need to buy heatsinks for the VRMs at least and have some sort of active cooling over them. You can't go wrong w/ the Swiftech MCW80s.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
  #42 (permalink)
Old February 4, 2011, 12:49 PM
Slaughter's Avatar
Sounds good! I wasn't sure if a full cover provided that much more cooling vs. a universal or if it was close to the same.
As far as active cooling, is there something in particular I can use or just jury rig a 120/140mm fan to blow over them?
  #43 (permalink)
Old February 4, 2011, 01:18 PM
lowfat's Avatar
Nothing wrong w/ jury rigging.
Queen of Dreams WIP
Big Lian Li
Complete
  #44 (permalink)
Old February 4, 2011, 01:34 PM
Slaughter's Avatar
Sounds like a plan! Thanks again.
  #45 (permalink)
Old February 14, 2011, 10:36 AM
Slaughter's Avatar
Questions about Fittings!
TFC vs. EK vs. Enzotech compression fittings
Is there one that is better than the other? Or all they all about the same? I excluded Bitspower as they are double the price and out of my budget.
Is there a general guideline to follow in what type of supplemental fittings I might need? i.e. 45* Rotary, 20/31mm extender, etc.
As I'm running push/pull on my rad, I assume I'll need some extender pieces. Fans are 25mm so would a 20mm extender with a 45 rotary fit? Or would that be cutting it close?
This is what I think I'll need:
8x Compression Fittings
4x 45* Rotary Fittings
2x 20mm Extension fittings
Any advice is greatly appreciated :)
  #46 (permalink)
Old February 14, 2011, 10:42 AM
Dazmode's Avatar
All made in China, possibly on same factory, but you get different packaging bags.
Orange Build: Final Video
HTPC Build: Final Video
  #47 (permalink)
Old February 14, 2011, 10:52 AM
Slaughter's Avatar
Fair enough! Thanks :)
Just filling up my shopping cart :P
Still need some advice on the number of fittings.. :P
  #48 (permalink)
Old February 14, 2011, 07:40 PM
Prolab's Avatar
You a need a pair for the following:
- CPU Block
- Reservoir
- Pump
- Rad
So that's 8 right there. I have 12 fittings just in case i add another loop (most likely). If you dont end up using it, you can always sell .
As for the ext and 45's... they're well worth it.
Gaming Rig:
-Caselab STH10, Swiffy MCP35x2, (2) Aphacool UT60 480 rad, HWL GTX 360, Heatkiller IV, i7 5930k @ 4.5 Ghz, 16GB Ripjaws, Asus X99 Deluxe ii, (2) XFX R9 290 w/ XPSC WB, 240 GB Intel 530, 500 GB 850 EVO, (6) 3 TB Tosh HD, EVGA G2 1300 PSU, Win 10 Pro
HTPC Rig:
-G3258 @ 4.0 Ghz, Asrock Z97 Pro 4, Asus 290, 128 GB Crucial M4, (2) 2 TB WD Green, (1) 2 TB Sammy F4, (2) 5 TB Tosh HD, Enthoo Primo, XSPC 480, 240 HWL GTS, Corsair HX620, Win 10 Pro
  #49 (permalink)
Old February 14, 2011, 08:58 PM
Slaughter's Avatar
- CPU Block
- Reservoir
- Pump
- Rad
So I'm pretty well on track then.. What length are those extensions?
  #50 (permalink)
Old February 14, 2011, 10:09 PM
Prolab's Avatar
Its a 31mm ext
31mm Dual Connecting Spacer Adapter Male/Female - Silver Shine 31mm Dual Connecting Spacer Adapter Male/Female - Silver Shine [MFL-G14] - $7.99 : DazMode, Canadian PC Water Cooling and Modding Store
Gaming Rig:
HTPC Rig:
New To Water Cooling mjbdc07 Water Cooling 10 August 31, 2010 05:25 AM
new to water cooling LacrosseTown Water Cooling 11 May 19, 2010 01:50 PM
New to water cooling SquattingDawg Water Cooling 30 July 12, 2009 03:40 PM
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
