-   -   mCubed T-Balancer miniNG (http://www.hardwarecanucks.com/forum/water-cooling/38045-mcubed-t-balancer-mining.html)
JD November 16, 2010 08:48 PM
Any thoughts on using the mCubed T-Balancer miniNG to control a DDC3.25? It's the noisest component of my PC, so I want to tone it down a bit. However I'm not sure how much of a hit I should expect on temperatures...
Let's say I run it at 9V, and I have a HK 3.0 on the CPU, EK 5870 FC and HWLabs SR1-360. 45's on the CPU, quick-disconnects on the radiator, and XPSC Dualbay DDC res. Would that dip under 1GPM?
Alternatively, do you think my Lamptron FC6 could run it? I think it's rated at 20W, but I'd be concerned about the pump not starting up with low-voltage.
