Originally Posted by Fudd Rucker also a major concern i have with this unit is the melting method as my gpu block is first in my loop and I cant imagine it would be good for the gpu to be ran for a minute or 2 without waterflow going through it. |
I unplugged my GPU from the slot and rested it beside the slot (since there's not much slack in the tubing).
It's just way too much hassle for no results really, but it's up to you. If you have like 30-45 minutes to kill, then go for it. You basically want a "clean-room environment" though as there shouldn't be any dirt/dust on the chip.
