-   -   EK Supreme HF 1/2ID 3/4OD compressions, they fit? (http://www.hardwarecanucks.com/forum/water-cooling/38003-ek-supreme-hf-1-2id-3-4od-compressions-they-fit.html)
lowfat November 15, 2010 12:42 PM
Can't find any definite answers to this. Some say yes, some say no.
KaptCrunch November 15, 2010 12:45 PM
yes with a 45 on one holehttp://i71.photobucket.com/albums/i1...2_28776149.jpg
KaptCrunch November 15, 2010 12:55 PM
http://i18.photobucket.com/albums/b1...0/DSC_0293.jpg
copper or plastic
lowfat November 15, 2010 01:00 PM
I have the acetal top. I'd rather not use a 45˚ adapter.
vohiep84 November 15, 2010 01:50 PM
EK Supreme HF has two revisions.
2nd revision came out so that there was enough spacing to fit 1/2ID 3/4 OD compressions.
EK Waterblocks EK-Supreme HF Universal Socket - Acetal+Nickel - Rev 2 <-- revision 2
Not sure how to find out which revision you have, but when you do, you'll find your answer.
Good luck!
matsta31 November 15, 2010 01:57 PM
Jsut curious, why do you not prefer using 45 degrees adaptors ?
lowfat November 15, 2010 02:00 PM
I don't like they way they look with compression fittings. :haha: Especially on blocks that have one 45 adapter while the other one does not.
vohiep84 November 15, 2010 02:02 PM
I forgot to add, I own the nickle plated EK supreme hf rev 2 and am using compression fittings of that size.
lowfat November 15, 2010 02:14 PM
How can I tell if I have a rev 2 or not? I'd hate to be able to use compression fittings on one block but not the other.
matsta31 November 15, 2010 02:25 PM
ah SR-2 fun... you went ahead with the project ? I hope we will have a build log.
