Water cooling question Teeline or reservoir? My old setup sort of ... "died", so I'm planning to go on a new set up with either a teeline or reservoir. Also, how big a gap is the performance between a 2 fan radiator and a 1 fan radiator. And btw, im trying to keep this all internal so I'm planning to use a 1 fanned rad. |
Personally, from what I've been reading, both have there advantages and disadvantages. A Res will fill/bleed the system faster and from what I heard, gives better performance, while a teeline takes up much less room. Second, it depends on what your cooling, and what rad your using :D |
I prefer using a res, but a T-line will be fine, it just takes a little longer to bleed. Could I get your budget for this build and the case you'll be using? Thanks. The double radiator will definitely be better than a single, unless if you go with Thermochill. |
Hands down, a reservoir speeds up the bleeding process, but it slightly impedes flow as well. The difference is fairly minimal, though. If you have room for a double rad, definitely go for it. Between equal rad designs, you need MORE than twice the airflow through a single to equal a double. Otherwise... what are you planning to cool? |
The case im using is the Antec P182.. I'm trying to keep it under $100 but I already have a pump and a CPU block. How is this rad? Swiftech MCR120-QP |
It might be a snug fit, but I'd aim for the MCR220, the dual radiator. If you didn't have a budget, I'd recommend the Thermochill PA 120.1 hands down (single rad), as it's a little better than the MCR220 (dual rad). |
Do all these components fit together? Thermochill Pa 120.1 Single 120MM Water Cooling Radiator *No Barbs* Masterkleer Pvc Tubing 7/16IN ID 5/9IN OD 10 Feet Danger Den Tubing Plug for 1/2IN ID Tubing (Single Plug)Swiftech Adjustable Black Hose Clamps for 1/2IN Inner Diameter 3/4IN Outer Diameter Tubing (2 Pack) Swiftech Hydrx Water Additive Coolant 2 oz Bottle Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs Polypropylene T for Water Cooling T Line 3/8IN Barbs |
No, they don't fit. The T-Line has 3/8s barbs - you need 1/2". Also, you are missing the barbs which are specific to the P120 - those rads have a special thread, if I'm not mistaken. Don't forget 1 fan for the rad. |
Oooo ok. Is this the barb im looking for? Thermochill 1/2IN Chrome Plated Barb Fitting G3/8 Threads *Single Barb* Im planning on using one of my case fans for the rad.. so yeah. Are you sure the tubing will work? It doesnt say its 1/2" Is there anywhere like Home Depot or Canadian Tire where I can get a 1/2" T line? Its sold out at NCIX.. :sad: |
That barb is what you need for the Thermochill rads. It's even in stock, go figure. If you're shopping at Canadian Tire or Home Depot, any T-fitting made of brass or copper with 1/2" barbs will do the trick. Check the plumbing section. The 7/16" tubing will work on 1/2" fittings, you might have to soak it in hot water to soften it a little first, but it's a snug fit once it's on. Thermochill's PA series are good, but I've never seen it demonstrated that a single can outperform someone else's double. If you have room for a double, you'll want it. On the other hand, if you're just cooling the CPU, a single rad should be up for the task. |
| All times are GMT -7. The time now is 03:37 PM. |
