Old December 26, 2007, 12:58 AM
Infiniti's Avatar
Ok Thanks. But I'm going to order my T from Danger Den.. so problem solved
Is there any BIG performance differences with the swiftech MCR120 and the Thermochill 120.1? The Thermochill is like about $90, while the swiftech is like $30, so is it worth it to get the Thermochill?
Old December 26, 2007, 11:11 AM
MpG's Avatar
MpG MpG is offline
Depends on what kind of fan you're running on the rad. To read the technical data they each provide, at higher fan speeds (2000 rpm), they'll have similar performance. The slower the fan goes, the more the Thermochill will pull ahead. The Swiftech is definitely going to provide a better value for the money, though. And it's thinner, which can make for easier mounting.
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
Water cooling fluid question tzetsin Overclocking, Tweaking and Benchmarking 47 February 18, 2008 04:13 PM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 09:22 PM
Water cooling build SHaCK Water Cooling 34 April 24, 2007 07:45 AM
Another DIY Water Cooling Rig Magnesious Water Cooling 5 April 14, 2007 11:51 AM
