  #21 (permalink)
Old February 20, 2007, 08:55 PM
Misoprostol
Guest
Posts: n/a
Did you remove the shim around the GPU?
  #22 (permalink)
Old February 20, 2007, 09:30 PM
Yes I did remove the shim around the GPU for the second attempt with the same results. That's why I then gave up on the water block as its pretty simple in design and should have fit really
  #23 (permalink)
Old February 21, 2007, 01:49 AM
Misoprostol
Guest
Posts: n/a
that's very strange....
  #24 (permalink)
Old February 22, 2007, 07:25 PM
cdn_Madrach's Avatar
Originally Posted by sswilson View Post
Before, during, and after pics with a quick description of the process and what went well, and definately what didn't... :)
Here's a link to the only one I've done.......
http://www.diy-street.com/forum/show...77&postcount=1
It's certainly not a template, but it should give you an idea of what kind of things folks might be looking for.
Thanks Wilson. That helps, I like how you posted mistakes and the pics were great. The last of my parts should be in early next week. Probably tackle it the week after that :)
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
  #25 (permalink)
Old February 27, 2007, 09:52 PM
Babrbarossa's Avatar
Default Well.. I did it!
I placed my WC order tonight and I'm feeling a little crazy-- still wondering i I would have been better off buying a second evga 8800gts before they go extinct-- I know that would have been the best performance boost seeing how I'm already running at 3.4 on my e6400 and 600/1000 on my gpu-- but hey WC is G.D. cool-- please feel free to offer encouragement......PLEASE!
  #26 (permalink)
Old February 28, 2007, 05:08 AM
WC is kewl and properly lit up always has a WOW factor lol. A friend of mine once described computers as being like cars or motorcycles. Always want one to go faster or look kewler. WC does that for computers:) Don't forget the pics, before, during ,and after. I started mine last night and took lots of pics. Should be able to mount the water blocks and drill the holes in my case tday.... I hope, provided the family cooperates lol.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
  #27 (permalink)
Old February 28, 2007, 11:22 AM
Supergrover's Avatar
Right on Guys
Cant wait for all those pics.
R.I.P.
  #28 (permalink)
Old February 28, 2007, 12:36 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Ummm....you might want to know that your 8800GTS has TEN memory modules (64MB X 10 = 640) and the Swiftech MCW60 only comes with EIGHT ramsinks. In addition, is the MCW60 contact area large enough to completely cover a G80 core?
  #29 (permalink)
Old February 28, 2007, 12:52 PM
Thanks for the heads up SKYMTL-- I looked at the compatibility list and it said it was good for all 8800 models, but I never considered that there wouldn't be enough ramsinks-- I'll look into it with NCIX.
  #30 (permalink)
Old February 28, 2007, 01:13 PM
SKYMTL's Avatar
Both the NCIX product page and Swiftech's site lists it as including 8 ramsinks. Buying this kit would probably be good for you:
http://www.ncix.com/products/index.p...cture=Swiftech
With that you woundn't need to buy the Mosfet coolers seperately.
