Old November 12, 2010, 06:46 AM
That should be fine, as long as the res is still feeding the pump :)
I know what you mean, you just need to tinker with stuff from time to time. I prefer to build PC's for other people, saves me spending my own money haha
Old November 12, 2010, 07:00 AM
Dashock's Avatar
yea sounds good just an odd question since im getting 1/2 tubes compared to the 7/16 i used to get they wont have a problem fitting on 1/2 chrome barbs will they or do i need to buy new barbs as well.
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
Old November 12, 2010, 08:26 AM
Fudd Rucker's Avatar
they will fit, carefully.
Soak them in very very very hot water and cram em on the fittings before they cool.
I couldnt think of something snarky or interesting to put here this time around.
Old November 12, 2010, 09:28 AM
Dashock's Avatar
thanx Fudd.
Asus P5Q-E
Antec Spot Cool
Logitech X-230
Old November 27, 2010, 11:59 AM
Dashock's Avatar
So i finished the loop out of curiosity using the primochill tube did u guys heat up the tube in hot water before sliding it in or not. I ask because it went in on my Swiftech barbs a little too easy and i kinda did not like that. Well the worse happened after filling it my Swiftech Block had a tiny leak luckily i put some paper towels around the area so i guess its gonna be delayed some more suggestions for a block and was it wrong for me to heat up the tube? yes no. I used zip ties to secure each barb i hope i didnt use the wrong barb i use the standard Swiftech i believe 1/2 inch.
Asus P5Q-E
Antec Spot Cool
Logitech X-230
Old November 27, 2010, 12:28 PM
sswilson's Avatar
If I'm reading this right you went from 7/16" tubing to 1/2" tubing? If so, that tubing will fit fairly easily over 1/2" barbs (what it was designed for), but having a proper seal with your clamps will be more critical to preventing leaks. (Many folks who run 7/16" tubing on 1/2" barbs don't bother with clamps at all).
Old November 27, 2010, 01:14 PM
Dashock's Avatar
yea it went on fairly easily it kinda had me worried lol but makes sense. but yea ill redo the fitting as i have to put in the new block now anyways ill add 2 zipties on each as you suggested.
Asus P5Q-E
Antec Spot Cool
Logitech X-230
Help Looking For Part hero_of_the_day Video Cards 2 April 29, 2010 08:18 AM
[FS] Watercooling part out - All Sold Lpfan4ever Buy/Sell & Trade 20 April 27, 2010 06:40 PM
[FS] Partial Part-Out jetOne Buy/Sell & Trade 11 December 27, 2008 11:35 AM
Upgrade Part II Phaddie New Builds 45 November 4, 2008 04:18 PM
WaterKegIII Extreme external Watercooling unit, Watercooling stuff Apollo4g Buy/Sell & Trade 9 June 9, 2008 09:49 PM
