Old November 9, 2010, 05:11 AM
AmuseMe's Avatar
Every where you look, you will find different info on 90-degree fittings. I can't see how OCN says that one fitting equals 4-feet though... Most places I've read said it was like one foot of tubing.
DEAD CA$H
Old November 9, 2010, 06:32 AM
Dazmode's Avatar
I did little test myself on single loop CPU loop with 3/8" tube on dual TFC rad. Each 90 degree fittings got me aprox 0.1 lpm drop in flow rate. In my books 4-6 of 90 degree fitting in set up is not a biggie at all.
You also always can do dual 45 degree adapters if space permits.
Orange Build: Final Video
HTPC Build: Final Video
Old November 11, 2010, 07:05 PM
Fudd Rucker's Avatar
If your using the same 1600rpm sflexs im using, id suggest you should use them to pull air off the rad, and not blow air through. I recently did that change and noticed a massive drop in temps.
I couldnt think of something snarky or interesting to put here this time around.
Old November 11, 2010, 07:45 PM
Keywork's Avatar
How massive are we talking exactly? Because I don't believe the difference between the 2 configurations should be that large; 1 or 2 degree IF THAT. The rad and fans aren't mounted to the case yet so changes can still be made if need be. Can you provide some more information on your setup?
Old November 11, 2010, 08:13 PM
My system specs are on the right and in must sig is my loop. My rad is on the back of an antec 300 via radbox, and the switching of fans brought down temps of about 11 degrees on chip and about 6 on the gpu. But my rad is considerably thicker so that might be a factor in this.
[WTB] Pump/Res/Rad kruzn4evr Buy/Sell & Trade 4 April 23, 2010 08:30 AM
[FS] e8500, 260 Core 216, DFI mobo, W/C Pump, Rad, Mushkin Ram, GPU/CPU Blocks + more Poison Ivy Buy/Sell & Trade 47 January 26, 2010 09:32 AM
[WTB] WC Gear Rad / pump / res / cpu water block anabioz Buy/Sell & Trade 8 December 17, 2009 03:33 PM
2X120mm rad dual gpu+cpu loop nckid4u Water Cooling 19 May 12, 2009 05:05 AM
WTB: E8xxx cpu, s775 water block & single 120mm rad 4wdrive Buy/Sell & Trade 0 November 9, 2008 07:32 AM
