Old October 27, 2010, 11:44 PM
mataribot's Avatar
I use a T line as a drain port. The leg of the T has a few bubbles. as soon as I kill the pump that air goes back into the system. I dont plan on ever turning it off so it should not be a big deal
Old October 28, 2010, 03:39 AM
KaptCrunch's Avatar
that indicates air in system, level changing when pump on/off
any pic of whole loop? or 0-ring cavitity on rez
a QC issue for eddy notes aren't smart
Old October 28, 2010, 10:12 AM
mataribot's Avatar
The fluid is now stable; the bleeding process just took longer than before. Here is a picture of my loop. Keep in mind that I due have some air in the leg of the drain port. That should not matter too much as long as I don't turn off the pump for long periods.
Old October 28, 2010, 11:47 AM
KaptCrunch's Avatar
ah top mount rad a bugger to bleed out air
best lay case on left side(mb bottom down) to get rid of trapped air .with rez upright
just run pump till air is bled then put back rez and case in position
Old October 28, 2010, 11:57 AM
mataribot's Avatar
Im positive that the loop is well bled atm accept for the drain port. the issue is my res leaking when stressed
Old October 28, 2010, 07:58 PM
mataribot's Avatar
Thanks for everyone who helped me. My rig is now up and running. I am still somewhat scared about the reservoir, but it seems to be not leaking atm. If the reservoir holds and does not leak, then the bottom was just not on tight enough. To ease my conscious, I am just going to buy a new reservoir different brand
Gamergrub Contest Leak ziikutv Rumor Mill 1 December 4, 2009 08:32 PM
F1 X-240 vs MCR320 and EK Multioption vs Swiftech Micro Res bottle Water Cooling 11 July 23, 2009 07:39 PM
x-men origins leak and box-office sales? magictorch Off Topic 10 May 1, 2009 06:33 AM
i got a LEAK! kyle_L Water Cooling 9 May 1, 2009 05:10 AM
Leak in T-line Phobia Water Cooling 17 June 9, 2008 04:37 PM
