Old October 23, 2010, 02:06 PM
jtf2's Avatar
Default bp compression and tygon ?
is this the barb to use
Bitspower Matt Black 7/16in. Compression Fittings for 5/8in. OD Tubing # BP-MBCPF-CC6
with this tubing
Tygon R3400 7/16in. ID 9/16in. OD Laboratory Tubing # AAE00032
it looks to be so,but the fitting says 5\8od,and yet the tubing is 9\16 od
thanks
Old October 23, 2010, 02:32 PM
lowfat's Avatar
You want the tubing and the fitting to match perfectly. If the barb is a 7/16ID 5/8OD then make sure you have 7/16ID 5/8OD tubing.
Old October 23, 2010, 02:35 PM
The tubing will fit the barb but when tightning the compression fitting to the barb the tube's thickness will be thinner than recommended and can cause leaks.
I have no experience with the two, I am just going from logic.
Old October 23, 2010, 02:43 PM
MpG's Avatar
MpG MpG is offline
If it works and you can actually get the collar over the tubing in the first place, you'll basically be trying to crank the comp down on tubing that's too wide, which usually makes for a pinch point above the barb, rather than on it (like it's supposed to be). Not recommended, in my books. If someone's specifically tried the combination and it works, that's fine. But my own experience with Tygon/BP comps says that there isn't a whole lot of clearance to be had. If you do, I'd definitely give it a good, long leak-test before letting anything power up.
Old October 23, 2010, 03:05 PM
jtf2's Avatar
so this then would be the proper tubing
Tygon R-3603 7/16" ID 5/8" OD Chemical Tubing - AAC00033
but now i need to see if anyone sells that in black?
Old October 23, 2010, 03:25 PM
Yep those work.
Just curious why those dimensions?
Old October 23, 2010, 03:36 PM
jtf2's Avatar
Originally Posted by vohiep84 View Post
Yep those work.
i find that they are just easier to work with than the 1\2id 3\4 od tubing,and in the end the flow loss is negligible.
i see that primochill sells that size tubing in black,now i just have to hunt down who has it!!
Old October 23, 2010, 04:29 PM
Here are the primochill's tubing in black and they do ship to Canada.
PrimoFlex Pro LRT Black Tubing -7/16in. ID X 5/8in. OD Products Model: PFLEXP-716-BK [PFLEXP-716-BK] : Performance-PCs.com, ... sleeve it and they will come
Do you have to tighten compression fittings ALL the way? Z Overlord Water Cooling 8 April 26, 2010 03:11 PM
Compression Fittings Phobia Water Cooling 9 September 17, 2009 07:25 PM
Compression Fittings micul Water Cooling 5 April 18, 2009 03:21 AM
FS: Fuzion V1 CPU block, Thermochill PA.160, Mushkin XP2 8500, Tygon 3/4", DD 680i... Apollo4g Buy/Sell & Trade 8 September 8, 2008 05:58 AM
Tygon tubing Dark Water Cooling 5 December 28, 2007 07:42 AM
