Old October 22, 2010, 09:00 AM
mattlef's Avatar
Default Anyone know anything about this XSPC kit?
Hey guys.
I was doing a bit of browsing.... attempting to find some decent air cooling for the TJ07 when I found this:
XSPC Rasa 750 RS240 Universal CPU Water Cooling Kit
I was wondering if anyone had any experience with this pump/res combo, and if you would think it would be a strong, value option kit for entry level WC?
My Rig:
Motivate TJ07
Check out my Build log!!!
Motivation: Sponsored by Galaxy
Upcoming Changes/Upgrades:
Check the build-log for more
Old October 22, 2010, 09:24 AM
lowfat's Avatar
It will definitely be good enough, and far better than any air cooler will get you.
Old October 22, 2010, 09:40 AM
mattlef's Avatar
Nice.
I wonder about the pump however.
If i was to at a later date add a 320 rad and a few 460 blocks, do you think it'll stress the pump too much?
My Rig:
Motivate TJ07
Old October 22, 2010, 09:46 AM
botat29's Avatar
Nice kit
Old October 22, 2010, 09:48 AM
JD JD is offline
Originally Posted by mattlef View Post
Nice.
You'd probably dip under the 1GPM "minimum" I'd say. You could probably add 1 block to it and swap out the radiator, but I wouldn't do anything else.
Old October 22, 2010, 10:08 AM
lowfat's Avatar
Nice.
Depends on the blocks more than likely. You may get away w/ it if i you stick to low restriction blocks. Blocks like the Koolance VID-NX460s, no way.
Old October 22, 2010, 02:28 PM
Yes this is a very good entry level water kit. From what I heard these sell out quickly on FrozenCPU.
Old October 22, 2010, 08:05 PM
mattlef's Avatar
hmmm,
i'm wondering if I should opt for a couple of those EK 460 blocks, adding another 220...
would i need to add another pump for redundancy? Would the two 220's provide enough cooling for a CPU and two 460s?
My Rig:
Motivate TJ07
Old December 30, 2010, 08:32 PM
mattlef's Avatar
Hey guys,
I've done a bit of research on this pump and apparently there are multiple other people who have used this pump with a multi GPU setup and multi rad setup.
Now, do you think I'd get more performance on a single 4.120 rad.... than say, 240 and one 360 rad? Considering the cost difference between the 360/480 rads are. (like 20-40 bucks depending on site)
My Rig:
Motivate TJ07
Double Checking - Adding 2GB kit to a 4GB kit? 2Supra4U RAM 5 February 26, 2010 12:54 PM
[FS] HTPC/Folding kit and Watercooling kit Synth Buy/Sell & Trade 4 February 4, 2010 08:45 AM
[WTB] DDR2 RAM 2GB kit or 4GB kit AFG34 Buy/Sell & Trade 4 October 19, 2009 08:24 PM
FS/T Visiontek 4870 X2 + XSPC FC block zlojack Buy/Sell & Trade 5 November 16, 2008 04:57 PM
looking for XSPC Laing DDC cryptospartan Buy/Sell & Trade 0 May 25, 2008 08:33 PM
